Old 02-07-2008, 08:45 AM   #1 (permalink)
wannasupra's Avatar
Member Number: 32741
Default progress
what happened to it, for awhile there we were getting fairly regular updates and the whole reflash thing was working better and better. what's the status on the pcm controlled boost, what about boost by gear, rpm mods, meth control? any progress? come on, i'm bored.
"Scoff not at my vile remarks horny fiend"
Quote: Originally Posted by Sweets View Post
^^ Im with supra..
Old 02-07-2008, 11:52 AM   #2 (permalink)
Member Number: 25021
I have some work to do. I am out of injector, so I am waiting on some cash to get here so I can take care of it. Not only that, but getting the time to tune is hard. I am almost out of meth, I have to pick more up. Hopefully I will have some time and good weather on monday.
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Mana4real is online now   Reply With Quote
Old 02-07-2008, 09:06 PM   #3 (permalink)
ojcool's Avatar
Member Number: 19382
Trader Rating: (12)
you got to stop the meth man, you've lost like 14 pounds but your car is faster...
ojcool is offline   Reply With Quote
Old 02-08-2008, 11:19 AM   #4 (permalink)
LMAO for sure!! I got 5 gallons yesterday on my lunch (damn that's a lot of shit)... No but really, the weather has been cool the past few days... Hopefully it stays nice and dry so I can work on it on monday.
Old 02-10-2008, 09:28 AM   #5 (permalink)
wannasupra's Avatar
cool. pics of bewbs or teh ban.
Old 02-10-2008, 03:31 PM   #6 (permalink)
Hayabusa's Avatar
Member Number: 31537
Hey wannasupra I see you over in the nitrous section a bit and since I saw you here thought I would ask. Do you have and use the SCT? If so do you have two maps set up, one for nitrous, and the other for all turbo? If so how is that working for you?
Hayabusa
Wanna race a cop? Click here: http://www.tnbeattheheat.com/
Hayabusa is offline   Reply With Quote
Old 02-11-2008, 11:18 AM   #7 (permalink)
wannasupra's Avatar
no, no spray just yet. i was over there quite a bit recently, i was in a class about N20 at school, and was considering a 35 shot for spool. i also don't have an sct, but am definetly considering one. once all the features i'm looking for (higher redline, recalibrated injector size, 3 bar map, gear based boost, and perhaps W/I) are functional and tested, i'll most likely be ordering an xcal. technically, the race gas map you're talking about could be activated via the HOM switch. it just depends on how that calibration is enacted in a stock pcm. if it's a whole different set of values, then you could have two separate tunes that could be accessed via a simple switch. if it's activated my modifying the values ie fuel, boost, timing: by a percentage of the base map, then as long as the percentages are tested, then it would still probably work. depends on how much time ojcool and mana4real want to put into it. if i can get a deal on a pro racer package, i'll probably go that direction, but i'd need a new laptop as well.
Old 02-11-2008, 04:55 PM   #8 (permalink)
Member Number: 31650
hey hey you stool my setup.. almost all my stuff is here just need warmer temp to install it
liek you said 25 or 35 for spool, and w/i,,,for now i'm at 6500 rpm, 750cc and 3 bar sensor
will use the coolingmist device to control w/i and nos
i will put boost back to pcm so it will lower with knock
my idea with the coolling mist...is to connect a flow sensor (dds3) for the w/i from aquamist (ordered this morning),afr,map,tps,rpm and speed
so knowing rpm and speed you can control by rpm and gear
and if afr is no good at wot i will by pass the boost sensor
Not stock anymore
Old 02-12-2008, 05:40 PM   #9 (permalink)
What do you want me to do? Waiting on bigger injectors. Should be here this week. I will be tuning more this weekend.
Old 02-13-2008, 10:25 AM   #10 (permalink)
wannasupra's Avatar
i'm in no hurry, i'm not installing shit until i get back home in june.
Old 02-13-2008, 11:11 AM   #11 (permalink)
Again, what exactly do you want me to do? You are talking about nitrous, but you didn't say what you are looking for us to do.
Old 02-13-2008, 12:01 PM   #12 (permalink)
wannasupra's Avatar
no, hayabusa mentioned nitrous. i mentioned some way to use the ic sprayer algorithm to control w/i.
the nitrous would have to have a standalone controller, or maybe just a two position switch, one which would ground out the solenoid, and let it spray, and the other would go to a n/c hobbs switch set at 15 psi. so position one, spray to spool, position two, spray to whoopass.
Old 02-13-2008, 12:02 PM   #13 (permalink)
wannasupra's Avatar
doesn't really matter right now tho, i'm stock until i get home.
Old 02-13-2008, 12:23 PM   #14 (permalink)
Oh I see... But we can't program the toys computers yet... Maybe not ever
Old 02-15-2008, 09:14 PM   #15 (permalink)
wannasupra's Avatar
that sucks. why not?
Page generated in 0.32735 seconds with 11 queries
