Old 04-24-2009, 08:02 PM   #1 (permalink)
julius717's Avatar
Member Number: 24352
Default OBD-AutoConnect error
what the hell is that? i just got my PCM and handheld back from sct first when i would try and flash it will say ECU UNLOCK FAIL car still runs and everything now it wont even connect just says OBD autoconnect error. i have checked over all my wiring everything is good i have nothing loose i drove the damn car around turned it off plugged in scanner so i know the battery is fine. im stuck and i have lost all my patience with this
DRASTIC
julius717 is offline   Reply With Quote
Old 04-24-2009, 10:50 PM   #2 (permalink)
apexcrazy's Avatar
Member Number: 24279
Ouch . I guess it could be one of three problem sets .
1. the handheld is no longer " married " to your ECU . If you have a "dealer flash package" , I would get in touch with your dealer shop . If you have a PRP version then you may have to restart the whole proccess you went through when you first bought it , or get with a SCT tech over the phone to resolve .
2. The handheld hardware is at fault . I would normally not consider this a high probability , but I have personally had a Xcal-II screw me , hardware wise . even if the handheld wont recognize your PCM as its "spouse" it should still be able to check for fault codes on any SRT4 . does it do this successfully on your car ? can you try it on another SRT4 ? If it cant I would think its safe to blame the handheld .
3. your PCM or OBD-II port is at fault . I suppose this is possible . if the handheld can check & clear trouble codes on another SRT4 , but not yours , i think its safe to blame your car .
You may be able to use a non SRT4 dodge to use as your handheld checker , I dont know if it can read non SRT4 OBD-II port for trouble codes , can anybody chime in on this ?
Sorry to waste your time if I am telling you stuff you already know . As a victim of this crud myself , I can sympathize with you .
_____ _____
apexcrazy is offline   Reply With Quote
Old 04-24-2009, 10:59 PM   #3 (permalink)
julius717's Avatar
^------ well if i go to handheld info it has my vin and everything in there. i just got it back from SCT when i called they said it worked fine and it has to be somthing wrong with my car...? makes no sense. only thing that i have that is odd is
1 i have my old AEM EMS cable soldered into my OBD harness still BUT its not connected or anything so i dont see how it can cause an issue
2: i have a few odd PCM wires that are re-connected with Barrel connectors im going to fix that tommorow.
wierd thing is yesterday it would connect it just wouldnt flash anything. im really starting to go crazy
Old 04-25-2009, 12:31 AM   #4 (permalink)
Mana4real's Avatar
Member Number: 25021
We connected my xcal to his car to check for codes to see if we would get the same thing as we did with his xcal and it gave the same error... I just didn't even think to check my car with his xcal... You can plug your xcal into any OBDII port to check for codes... Your vette or your charger... Either one will work. If it checks it, then you know that it's something on your car... That's why we checked my xcal on your car
-Matt- -SCT Tuned- By Yours Truely
Page generated in 0.13993 seconds with 13 queries
