Old 03-04-2008, 03:34 AM   #46 (permalink)
fr33fir3's Avatar
Member Number: 54378
I was told LM-2 was going to be $399-$599.. your paying for a screen and and SD slot imhop. I went with OT-1 since I own a laptop and want to see the analog graph while I am driving.. Not after the run.. I paid $349 for the 2 and got it now, no waiting.. But then again the one your looking at is portable from what I have read.
www.Kingclamp.com
For All your map clamp needs.
Major Upgrades:
AGP Motor Mounts, Agp WGA, Agp Hard pipe, Agp Shift Selector, Greddy BOV, LFS 60MM TB, PTP Charge pipe, PTP fuel pump rewire PTP, PTP Wga spring, Walbro 255 lph Fuel Pump. Stage 2 W/toys. Apexi Safc II, Devils Own Progressive W/I, Turbo XS HP MBC, Innovate LC-1 & Gauge,ACT Clutch & Flywheel.
fr33fir3 is offline   Reply With Quote
Old 03-04-2008, 03:39 AM   #47 (permalink)
THier's Avatar
Member Number: 8263
Yea I hate having laptop in car,,, I use my e-01 for data logging, and real time viewing passes but I want to be able to save all my logs. Can't do that with the e-01. The LM2 also has 32channel logging.
So basically it is an OT-1, LM-1, and DL32 in one unit. Phillipe (sp?) at Innovate said the single a/f unit will be $469.
Tom
THier is offline   Reply With Quote
Old 03-26-2008, 08:03 PM   #48 (permalink)
Member Number: 31650
Quote: Originally Posted by ojcool View Post
NOTE: after you program the OT1 with LM programmer and after you have all your serial devices connected to the OT1 THEN hook it up to the OBDII port with the vehicle ignition OFF. The only LED to be lit will be the Power LED. Then hook up the USB cable to the laptop. THEN turn the ignition ON. The LED to light will be the power, vehicle, and USB will be flashing all weird. Give the OT1 about 20-30 second to interrogate the PCM... THEN start the car. With the car running then you open LogWorks and push the "connect" button, sometime you have to push it twice. Everything should open up and be hunky dory. If you do something out of sequence sometimes you will get the following error. "no serial device found" or "no realtime data detected". Just start over.
i will have to try this tomorow, fuck it worked yesterday but today after trying for almost 1.5 h no fucking this thing is no consistant at all
some time it work some time it won't
yesterday i was able set boost in psi and it set it self from -14.7 to 28,88 by itself today no fucking it won't work but i don't think i did stop the car today
is it just me yesterday when dataloging it stop every few second for 1 or 2 second and start again
fuck this thing is not good at all for my patience...this fucking auto dection is a crap...just say witch com and that would be it ...damn
Not stock anymore
Old 03-26-2008, 09:30 PM   #49 (permalink)
Member Number: 62727
If it's giving you that much grief call innovate. They have excellent tech support and if there is something wrong with it or the firmware, let their tech figure it out. I call them at times and just play stupid so I don't have to do any thinking at all. If nothing else he will explain the sequence to hook it up so it works every time. My buddy got one and he had allot of problems with it and it ended up being an issue with the OT1, they sent him a new one and now, no problems. I had problems at first but once I called tech support and he showed me the boot up sequence it works every time now.
GT3076R, return line, stage II injectors, 4" short Ram, 3" Turbo back, STS, SCT Flash PCM managment.
----This is Ojcool, my account was put on a no access list for defending myself and other SCT section Members in OT----
There is such a fine line between stupid and clever. SPINAL TAP
Thermodynamics is offline   Reply With Quote
Old 03-27-2008, 07:45 PM   #50 (permalink)
i think i nailed it
i tried again tonignt car on car off bla bla bla all the light of the ot-1 were flashing but was not able to connect and different error code tonight
but but my mouse was still acting very funny...so i remembered reading somewere and when installing my usb seeing something trackball mouse detected
so i went into manage and look into the mouse and went to a ballpoint mouse and set it to deactivate
AND BINGO everything work's fine plug unplug car running or not work all the time
Old 03-29-2008, 10:12 AM   #51 (permalink)
do somebody know's if the engine load parameter equals to something we can relate to ???
Old 03-30-2008, 06:47 PM   #52 (permalink)
what do you put for psi range on the map setup
i tried -14.7 to 28.8 but my zero seem's a bit of by 3 psi
and so seem my higner value
Old 09-06-2008, 08:40 AM   #53 (permalink)
Buy/Sell Moderator
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (131)
I'm sure you figured it out already, but a 3 bar map is -14.7 to 29.4
11.9 @ 126
Old 09-06-2008, 08:59 AM   #54 (permalink)
yep but for some reason the obd2 doesn't datalog those value
-14.7 to 23 is what i use
if it goes over 23..the value roll over (+1 over 23 equal -14.7 +1)
the aeroforce gage seem to do the same thing
Old 09-08-2008, 04:12 AM   #55 (permalink)
my ot-1 was stopping datalog every 30 seconde or so for 1 or 2 sec
i updated the firmare of the ot-1 and switched to logwork3 and bingo
every thing is good now
Page generated in 0.17813 seconds with 11 queries
