Old 07-25-2008, 11:32 AM   #1 (permalink)
Member Number: 18641
Default Ltft?
My LTFT at low RPM seem kinda high after going through the tutorial on the wiki for changing injectors. I'm running DW 750's at 58psi FP with an AGP Return line. They're around +14 to +20 range from idle to about 2500 rpm, then they don't really go above +5. I had a nasty stumble at 2000 rpm when running 43psi but now that I've bumped it up to 58psi its moved to about 1500 rpm and is not as bad.
Now for the question. What would cause this at low RPM only? Is it my injectors pushing a lot more fuel during low Pulse widths then what i told it to compensate by?
Splitz is offline   Reply With Quote
Old 07-25-2008, 12:16 PM   #2 (permalink)
Nick Chestnut's Avatar
Member Number: 16791
It could multiple different things... Your fuel mass tables may be incorrect or your VE table at those RPM's may be off.
Have you tweaked your VE table at all yet? I find it rather strange that the PCM is adding fuel with those 750's after nothing more than a fuel mass correction... Are you sure your fuel mass tables are correct? Have you tweaked anything else that related to fuel?
- Nick Chestnut
* 2004 Dodge SRT-4, GT3076R, SCT Tune, 408 WHP w/o SCT and waiting on new numbers with SCT!
"Don't argue with an idiot. They bring you down to their level and beat you with experience." - Unknown
Nick Chestnut is offline   Reply With Quote
Old 07-25-2008, 12:33 PM   #3 (permalink)
Member Number: 25021
On the low end, I noticed I had pull fuel in the low end (after adding fuel) to get the fuel trims correct in the fuel mass table. Top end, I am still working on it. I won't be able to continue until monday though. Once I am done, I am posting my work up... That was a lot of work. I don't know when it's going to be done though.
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Old 07-25-2008, 12:36 PM   #4 (permalink)
I haven't touched anything else yet. I'm really trying to do one thing at a time so I don't have to trouble shoot too many changes at once. I haven't even set it up for rising rate yet.
Old 07-25-2008, 02:09 PM   #5 (permalink)
hmmm in my case it looks like i'd have to add more fuel so i'll have to lower my multiplier. I made a nice little spreadsheet that does all the work for me
Old 07-25-2008, 04:33 PM   #6 (permalink)
Exactly. You add fuel for the computer to see by decreasing the multiplier
Old 07-26-2008, 10:40 AM   #7 (permalink)
Super Moderator
Nick Fury's Avatar
Member Number: 19761
This is a stupid question, but did you try resetting the ECU? Like actually unplugging the negative from the battery and leaving it unplugged for a while?
I had a similar issue, thinking that every time I falshed the ECU was getting reset, and it kind of is, but its not resetting teh LTFT's. After I reset it, my fuel trims went from 20+ to +5 and have been there for a while ( I could probably tune them closer to 0, but I don't really care since the car drives so nice now).
Sorry if you already tried that step, Im just throwing it out there
Nick
Need Boost
Nick Fury is offline   Reply With Quote
Old 07-26-2008, 10:41 AM   #8 (permalink)
Super Moderator
Nick Fury's Avatar
Want to share it with everyone? I can add .xls files as a supported filetype on the wiki so you can upload and host it there if you would like
Old 07-26-2008, 10:51 AM   #9 (permalink)
JANNETTYRACING's Avatar
Member Number: 10982
Nick
That is absolutely correct, everyone needs to know this, you have to disconnect the battery or if your scanner has the capability reset the LTFT everytime you make a change.
A better way would be to lock out of closed loop to prevent LTFT from affecting anything and just work with the STFT.
Ted.
JANNETTYRACING is offline   Reply With Quote
Old 07-26-2008, 12:21 PM   #10 (permalink)
you guys are spot on about resetting the battery, I've already had figured that out the hard way. I made some changes and was totally confused as to why my LTFT hadn't moved as much as they should have, so I pulled over disconnected the battery while I went for coffee
How are you guys locking out the closed loop? I was thinking about it and the only thing I can come up with would be to change the Min coolant Temp for Closed Loop value to it would never hit.
As for my spreadsheet its kinda only useful to people runing my ECU code but i'll clean it up and post it if you'd like.
Old 07-26-2008, 05:16 PM   #11 (permalink)
I also have been unplugging the battery everytime I tune. I am also curious how you lock it out of the LTFT's. That would be useful since that is what I am working on right now. Thanks :-)
Old 07-26-2008, 10:57 PM   #12 (permalink)
Member Number: 31650
for me i had some 20+ ltft at idle and i have 750cc DW
if you look at the line of pw to fuel mass there is a small curve a the beginning of it...hard to see.
i put this part strait and my ltft have fallen a bit so maybe down low specially at idle the line should be a curve but not like the stock one
if you want to see it visually...put the last 5 values at the same lower value
to give you more perspective
probably that curve should be moved a bit since the injector opening time change a bit from injector size and this one is there for the stock size
at idle my gage show inj at 1.2 ms...stock would probably be a bit bigger
Not stock anymore
moreause is online now   Reply With Quote
Old 07-30-2008, 07:30 PM   #13 (permalink)
ojcool's Avatar
Member Number: 19382
Trader Rating: (12)
Can you set up the baord to allow file posting right on here? The attach files function would be great if it supported .mtf files for tunes ect....
Every human being is ignorant, only on different subjects.
ojcool is offline   Reply With Quote
Old 08-01-2008, 02:16 AM   #14 (permalink)
to attach files you have to be an upgraded member ...
and probably mtf files would have to be added to the list of correct extension
Old 08-01-2008, 09:48 AM   #15 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (47)
Well when posting the file, just inform that you are changing from xxxx.mtf to xxxx.gif so whoever downloads it has to switch it back... this will allow you to post it up.... i'm pretty sure you can share zips though too...
a853rox is offline   Reply With Quote
