Old 06-17-2008, 11:03 AM   #1 (permalink)
Member Number: 25021
Default Just ordered a stage 3 big wheel
Ok, I just ordered a stage 3 setup. I ordered the green turbo setup from forced performance... I am sick of being slow lol. What tune should I use? Should I use the stage 3 PCM code as a base or should I use the stage 2 setup and just modify it? I don't have a return line, so no boost reference...
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Mana4real is online now   Reply With Quote
Old 06-17-2008, 12:02 PM   #2 (permalink)
JANNETTYRACING's Avatar
Member Number: 10982
Looks like a good piece, Congrats.
You will need a boost referenced Regulator with those injectors.
I would like you to try my tune in that combo.
Ted.
JANNETTYRACING is offline   Reply With Quote
Old 06-17-2008, 12:50 PM   #3 (permalink)
Ted.
Can I call and talk to you?
Old 06-17-2008, 01:04 PM   #4 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (171)
47lbs............
PTperformance PTP's Cali CREW Mole'
100% BONE STOCK.
Old 06-17-2008, 01:10 PM   #5 (permalink)
Member Number: 64760
Trader Rating: (10)
its gunna anal rape.
jus be careful on how much timing/boost you run on pump.
26psi and that high timing you like isnt gunna work out well on pump w/ a larger turbo like this..
im interested to do some runs.
get it on before my head goes on.
91PumpKing. is offline   Reply With Quote
Old 06-17-2008, 01:18 PM   #6 (permalink)
Well I will tune to what it can take... I am actually running lower timing now... I need an O2 housing if I am going to get it on. Turbo should be here friday.
Old 06-17-2008, 01:22 PM   #7 (permalink)
Trader Rating: (10)
if u get the 02 too, hit me up sunday (if you dont install it by sat, since i wont be home sat). you can come over or vice versa and we will crank it out.
Old 06-17-2008, 01:27 PM   #8 (permalink)
Hell YA!!! Lemme see what I can do...
Old 06-17-2008, 10:05 PM   #9 (permalink)
quicktalon11s's Avatar
Member Number: 52950
It's an awesome turbo. I got the first one a while back. I'm working on getting it going with e-85 soon. I'd try stage 2 code modified to your taste. stage 2 used the 3 bar sensors and wasn't rising rate.
quicktalon11s is offline   Reply With Quote
Old 06-19-2008, 09:40 AM   #10 (permalink)
wannasupra's Avatar
Member Number: 32741
return line and rrfpr. then use the stage 3 code.
"Scoff not at my vile remarks horny fiend"
Quote: Originally Posted by Sweets View Post
^^ Im with supra..
wannasupra is online now   Reply With Quote
Old 06-19-2008, 09:51 AM   #11 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (47)
Keep in mind guys/gals that the FP 'green' spec turbo is the one with the 47lb comp wheel AND the upgraded turbine side.... expect a little later spool (~3600-3700rpm compared to 3400 with just the 47lb wheel) but significantly more power potential. The regular 47lb upgrades will max out in the 440-460range depending on setup and the 'green' should max out in the 500-520whp range....
I'm no tuner, but I would not assume that you can use the same timing as a stock S3 or even a typical big wheel S3 tune... I'm sure Ted knows this and will tune accordingly as he is quite the accomplished tuner...
Looking forward to seeing the results!
$.02
a853rox is offline   Reply With Quote
Old 06-19-2008, 10:40 AM   #12 (permalink)
$.02
Honestly, do you recommend porting the manifold before I install it?
Old 06-19-2008, 11:01 AM   #13 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (47)
Thumbs up
Well before any turbine upgrades, the S3 is one of the manifolds that I work on that show the GREATEST gains out of just about anything else The caveat to that is although I have ported and coated two manifolds for FP specifically, I have yet to see any real world results from them let alone a true side by side comparison....
With that said, I do think there is merit to the portwork on any cast manifold. As in FFP's recent testing with AGP's manifolds, we were able to prove that not only is overall power increased but spool is reduced from the portwork and coatings.... So it's up to you to decide if porting the compressor cover and manifold for $395 +shipping (+90 if you want the ceramic option as well) to gain maybe 20-35hp (speculative at this point) and decreased spool time, is worth it. Most S3 kits go from hitting full spool ~3100-3200 down to ~2700ish after portwork but I honestly don't expect as dramatic of a reduction in spool from the portwork as the larger turbine wheel is already helping out the the high backpressures already but I do expect benefits never the less... maybe from 3600-3700 down to ~3400-3500?
ported and coated S3 on the right, ported 'green' spec S3 on the left:
Old 06-19-2008, 12:24 PM   #14 (permalink)
Holy shit!! Why is the green spec ported so much more then the other ported stage 3?
Old 06-19-2008, 12:31 PM   #15 (permalink)
Trader Rating: (10)
well they gotta machine it a lil larger to be able to fit the LARGER turbine wheel.
nooby!
