Old 05-26-2008, 08:36 PM   #1 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
Default Its alive!
Well finally after over 2 years of waiting the car is alive and running again. In the past two years it has ran here and there for a week or so at a time, but havent put no more then maybe 200 miles on it last year at the most.....and that was because I made one trip out of state and back where I put most of those miles(115).
Well anyhow all new goodies on the car, new engine harness, and the SCT on the car. I have the car set at the stock static rate even though I have a returnline kit for now. When I bring it to the tuner everythings going to get rescaled so thats when we will set it at 43 and attach the 1:1 line. Here are my mods....what I can remember...
35R turbo with GT40 wheel and .63 a/r housing
DNP equal length exhaust manifold
Custom 4 inch downpipe with 4 inch SEE all done by PTP
70MM TB and 70MM ported tubular intake manifold
750cc injectors with -8an feed and bottlekneck fix on pump
walbro 255 high output pump
fidanza cam gears with 2.0 cams
BFMIC
Clutchmasters stage 4 6-puck clutch
AGP shift selector and tranny mount
DCR oil pump, crank scraper, baffle, windage tray, top end modifier
PSIFI motor mounts
80% reduction slowboy racing shifter
profec B Spec-II boost controller
Coolingmist dual stage water injection kit
NHRA approved batt relocation to trunk(check my writeup in the how to section)
PTP hotside charge pipe ED coldside charge pipe
PTP coolant overflow kit
3-bar map sensor SCT tuning package of coarse
Last but not least a fire extinguisher!
I think thats it....the only issue I have right now is shifting. Issues with that can be found here.... cable binding? I dont know, but hopefully its just something wedging itself on the cable....dont know what since none of that was even touched. If it is in fact something with the tranny or the clutch I saw screw it. I already have plans on getting a built automatic built for me and it would be cheaper anyhow. A stage 3r manual tranny is over 3k...new clutch to handle the power I am going to throw at it is around 1k itself. For just over 3 maybe 3.5k at most I can have a manual valve body built automatic.....so I think I am going that route instead since I was anyway. I am hoping its just something simple like the cable is screwy, but I dunno.
Shop hours are 10am to 7pm Mon-Fri
Taking calls on Tuesdays and Thursdays
Old 05-26-2008, 10:13 PM   #2 (permalink)
Falbz's Avatar
Member Number: 22294
Trader Rating: (58)
Nice man...................glad to see you got the car running So far SCT's working good for me too.
To make a purchase please go to http://www.pt-performance.com/
Falbz is online now   Reply With Quote
Old 05-26-2008, 10:17 PM   #3 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (65)
didnt realize your car has been down for so long
Built by experts. Tested in the real world.-Mopar
For sound Install/Tuning assistance: (727)512-9684 or PM
Now serving Upstate SC/N. GA SRT4 community
<---My modest 305fwhp "project" car in progress
Old 05-26-2008, 10:36 PM   #4 (permalink)
Member Number: 53357
Thumbs up Dyno Time!!
I wanna c some dyno #'S!!!
acesblack05 is offline   Reply With Quote
Old 05-26-2008, 10:48 PM   #5 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
Yea changing turbos...waiting on new one to get built, then piggyback issues, then manifold issues, etc, etc.
Yup soon as I find some more money somewhere
Old 05-27-2008, 10:29 AM   #6 (permalink)
Member Number: 48080
Congrats! I know how that is, just got mine running after about a year and a half.
I'll put a Stage 2 (3 bar) cal scaled for 750's with rev and speed limit raised on my website when I get home from work tonight. I'll post the link after it's up.
If you set your fuel back down to 43psi and flash the tune I'll be posting later to your PCM it will be a good baseline to run around on until you get it to your tuner.
One of a kind custom turbocharged 2004 Chrysler Sebring LX Sedan
.:CarDomain:.
SebringLX is offline   Reply With Quote
Old 05-27-2008, 06:26 PM   #7 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
sweet deal that would be great to have it back down to 43psi and ready to be tuned. Did you take the time and make it rev higher? I heard it stops up top and you have to do some extra work to make it work efficiently past like 6500rpm. All I want is a 7k limit until the head and such get done.
Old 05-27-2008, 09:22 PM   #8 (permalink)
I made a new thread for the generic tune so it will be easy for people to find. I'm sure it will be usefull for others too. New thread is here: Generic Tunes
Page generated in 0.16855 seconds with 11 queries
