Old 10-15-2009, 12:29 PM   #16 (permalink)
SRT-What?'s Avatar
Member Number: 10224
and that's why I had to get an DS on top of my SCT....
SRT-What? is offline   Reply With Quote
Old 10-30-2009, 08:19 PM   #17 (permalink)
Member Number: 57992
DoodEdge, you get everything you need? I have screen shots (.jpg) of EVERY S3 table that I can probably zip & email to you....if you're interested. I also have screen shots of all stock 05 base code tables as well.
tcain02 is offline   Reply With Quote
Old 10-31-2009, 12:02 AM   #18 (permalink)
Member Number: 69186
Trader Rating: (10)
I could use the stock coasting fuel shutoff tables if you don't mind :-] There are three tables under that file. Scalars, MAP Threshold to Enable Coasting Fuel Shut Off, and Time Delay to Enable Coasting Fuel Shut Off.
If I could have a screen shot of those three tables stock I would really appreciate it :-]
DoodEdge is offline   Reply With Quote
Old 11-01-2009, 08:14 PM   #19 (permalink)
Old 11-01-2009, 11:17 PM   #20 (permalink)
Trader Rating: (10)
Thanks!!!!
Old 11-02-2009, 11:32 AM   #21 (permalink)
SebringLX's Avatar
Member Number: 48080
You know, instead of screen shots, someone could have just exported the values to the .mvf file and he could have loaded them into his Stage 2 code...
One of a kind custom turbocharged 2004 Chrysler Sebring LX Sedan
.:CarDomain:.
13.5 @ 102mph
SebringLX is offline   Reply With Quote
Old 11-02-2009, 12:32 PM   #22 (permalink)
Trader Rating: (10)
I don't mind imputing it myself
Thanks though
Old 11-02-2009, 08:24 PM   #23 (permalink)
I've also been working on building a S3 tune from the S2 base code....I have a FnF P&P S3 that I'll be running on PCM controlled boost, DW750s (returnless), 3Bar MAP + TIP, etc.
It isn't tested yet, but here are my notes from the build. Mostly just trying to get organized and get SCT some feedback on all of their bugs in the S2 & S3 codes. Once I get this working & dialed-in, I'll gladly share the .mtf.
Old 11-02-2009, 11:03 PM   #24 (permalink)
Trader Rating: (10)
These are some good references, thanks
Old 11-03-2009, 07:41 AM   #25 (permalink)
04blusrt_4's Avatar
Member Number: 60369
If anyone wants my rescaled S2 tune (converted to S3) to 7k rpms in all tables, let me know. The only thing off in the tune is the PE is a bit raped to accomodate my methanol, but I have tested the underlying values and see pretty consistently the commanded AFR = Actual. Right now I command around 12.3-12.4 AFR but with the meth on get around 11.5AFR. You will have to monitor closely your AFR and make adjustments. Also the wastegate settings are untouched from S2 code since I am manual boost.
It is scaled for DW750s, 1:1 returnline (hooked to vacuum and boost, set to 58psi static with nothing hooked up).
*NE 400 Club*
Page generated in 0.13625 seconds with 13 queries
