Old 04-30-2009, 05:08 PM   #1 (permalink)
Member Number: 31650
Default how much is timing playing on afr??
last summer i was running on the safe side at around 10.5 afr
with modified timing
during the winter i just putted the timing to stock and afr was not that bad
but with hoter temp i'm falling to aroun 9.8 to 9.5 afr with no good result
just asking will put back previous timing anyway to see
Not stock anymore
Old 04-30-2009, 05:24 PM   #2 (permalink)
Nick Chestnut's Avatar
Member Number: 16791
Sorry dude... I'm confused. What are you asking?
Note: I am no longer offer tuning services. Please contact another vendor for tuning. I'm no longer going to compete with people who half ass things, make empty promises, and insist on flat out doing things the wrong way. I apologize for any inconvenience this may cause...
* Nick Chestnut *
* 2004 SRT-4, GT3076R @ 498WHP/502 WTQ *
Nick Chestnut is offline   Reply With Quote
Old 04-30-2009, 05:31 PM   #3 (permalink)
does changing timing affect wot afr
is this better
Old 04-30-2009, 08:14 PM   #4 (permalink)
Mana4real's Avatar
Member Number: 25021
is this better
In short, yes it will...
-Matt- -SCT Tuned- By Yours Truely
Old 04-30-2009, 08:43 PM   #5 (permalink)
SRT-What?'s Avatar
Member Number: 10224
I haven't seen a big difference on my side. A couple of points, but nothing to bring you back to 11.5
SRT-What? is offline   Reply With Quote
Old 04-30-2009, 09:09 PM   #6 (permalink)
i will check a bit else were i uped the afr but the car is still stumbling
time for new plugs
Old 05-01-2009, 08:40 AM   #7 (permalink)
SebringLX's Avatar
Member Number: 48080
Yes, more timing = burns more fuel = runs leaner.
One of a kind custom turbocharged 2004 Chrysler Sebring LX Sedan
.:CarDomain:.
13.5 @ 102mph
SebringLX is offline   Reply With Quote
Old 05-02-2009, 09:43 PM   #8 (permalink)
quicktalon11s's Avatar
Member Number: 52950
i advanced my timing around 6 degrees and my afr's did not change at ALL. logic above seems flawed to me. more timing doesn't burn more fuel. it changes when the spark happens which changes overall cylinder pressure. fire the spark earlier (advanced), the more cyl. pressure you have. fire the spark later (retarded) the spark fires later reducing cyl. pressure. the amount of fuel going in is controlled by the injectors. you won't run leaner by changing when you fire the spark. you could run leaner because of things that affect the a/f mixture. like injectors, vacuum leaks/boost leaks etc.
oh btw sebring, i live in elgin and have a spare set of stage 2 mopar injectors you could try out for a bit to see if you DW injectors are the problem. i have fic 900's on the car right now.
quicktalon11s is offline   Reply With Quote
Old 05-02-2009, 11:34 PM   #9 (permalink)
from what i heard
if you advance timing and it's beneficial (more power)
if more power you have 2 choice.
1-you used the same mixture but transfered more power to the crank
2-you used the same mixture but you burn it better (more power) resulting in a leaner afr
Old 05-06-2009, 07:35 AM   #10 (permalink)
JANNETTYRACING's Avatar
Member Number: 10982
I have seen instances where advancing the timing does lean the AFR, but that because I start with Low timing and work up.
So if timing is retarded it can show up as a rich mixture but not more than about .5 AFR.
Misfires show up as lean, exhaust leaks show up as rich.
JANNETTYRACING is offline   Reply With Quote
Old 05-06-2009, 09:10 AM   #11 (permalink)
harvboi05's Avatar
Member Number: 30703
if the plug is fired late a smaller percentage of the total injected fuel is burned and the rest of the unburned HCs comes out in the exhaust and is read as "rich" by the 02.
if the plug is fired early, a larger percentage of the total injected fuel is burned and less unburned HC are read in by the 02, making the exhaust sample "leaner."
there is a more complete combustion cycle, aka burn more of the injected fuel with optimum timing, affecting the AFR.
agp S3D 48 kit. 12.37@118.7 and 12.54@122.4.
^^car for sale!
http://www.srtforums.com/forums/f165...ate-ny-521715/
fwd = bad.
new addition: 98 cobra
harvboi05 is offline   Reply With Quote
Old 05-12-2009, 08:14 PM   #12 (permalink)
ojcool's Avatar
Member Number: 19382
Trader Rating: (13)
Timing changes can have a drastic impact on your A/F ratio.
I am trying to pass off my shifter as a Maddog shifter so I can make a quick buck.
ojcool is offline   Reply With Quote
Old 05-12-2009, 08:38 PM   #13 (permalink)
finally my afr change was caused by a clugged cat
problem solved
Old 05-13-2009, 11:37 AM   #14 (permalink)
all i'm saying is i saw ZERO change in my afr adding 6 degrees + timing.
Old 05-13-2009, 01:37 PM   #15 (permalink)
nemiro's Avatar
Member Number: 32732
Trader Rating: (165)
It was there, whether your WBO2 could pick it up, or not.
Neil Emiro
2005 Dodge SRT-4
Page generated in 0.21529 seconds with 13 queries
