If you have the pro racer package , open the advantage software & under the fuel section open the scalars , there are three values that deal with this . stoic fuel ratio , even cylinder stoic , odd cylinder stoic . some base codes different values input here . See SCT wiki for proper explanation , but suffice to say by changing this value you can slightly influence afr target . I think mine are currently set at 0.0689 , which seems to get me 14.6-14.7 afr at idle .
_____  _____
