Old 10-17-2009, 12:46 PM   #1 (permalink)
Member Number: 75700
Default High Timing under boost- Why!?
Im trying to tune the srt4 using SCT. It runs, drives great. WOT is a different story, it will run upwards of 35* timing, Ive adjusted every table to compensate, but nothing seems to work.
05 stage 0, but am using a stage 3 map for the map/tip sensor calibrations(3 bar sensor, 50trim kit).
please, if your intersted in looking at the tune, plase PM me.
taylork057 is offline   Reply With Quote
Old 10-17-2009, 12:53 PM   #2 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
what boost are you running?
are you sure your adjusting the right PSI range WOT tables?
bene is offline   Reply With Quote
Old 10-17-2009, 01:05 PM   #3 (permalink)
20-21
Yes, I even tried to make the whole row(4k and up) all levels the same, and it ignores that, im now reverting back to stock and working with the stock map sensor again, seeing is maybe i should not have jsut started with a stage 3
Old 10-17-2009, 01:18 PM   #4 (permalink)
nemiro's Avatar
Member Number: 32732
Trader Rating: (165)
Sounds like you do not have the calibration properly scaled for the 3 Bar MAP/TIP.
Neil Emiro
2005 Dodge SRT-4
Old 10-17-2009, 02:03 PM   #5 (permalink)
SRT-What?'s Avatar
Member Number: 10224
Hom ?
SRT-What? is offline   Reply With Quote
Old 10-17-2009, 02:57 PM   #6 (permalink)
bene's Avatar
Trader Rating: (40)
ya put stock one back in and give it a shot.
if it works PM nemiro and he will get you straight on the reflash
Old 10-17-2009, 03:28 PM   #7 (permalink)
seems to be much better with the stock pcm file, i couldnt imagine they would be completly different. Timing is dropping as it should, now just time to get the air fuel straight
Old 10-22-2009, 02:32 PM   #8 (permalink)
04blusrt_4's Avatar
Member Number: 60369
stage 3 code flashed to a non-toys pcm will default to High Octane Mode everytime you turn the car on.
Use a stage 2 code instead.
*NE 400 Club*
Page generated in 0.14246 seconds with 13 queries
