Old 07-24-2008, 12:11 PM   #16 (permalink)
ojcool's Avatar
Member Number: 19382
Trader Rating: (12)
How much boost are you running?
Every human being is ignorant, only on different subjects.
ojcool is offline   Reply With Quote
Old 07-24-2008, 12:44 PM   #17 (permalink)
Member Number: 25021
The boost doesn't matter at this point. It won't run in the upper RPM range at all because it's so rich... I will get to it, I just haven't had time to work on it since monday... I will get around to it on monday again. It's just a pain in the ass.
But the boost is spike 23 and 18 at redline... 91 pump gas, no meth, no knock.
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Mana4real is online now   Reply With Quote
Old 07-24-2008, 01:32 PM   #18 (permalink)
Member Number: 31650
is it better power wise to lower boost near red line ??
for now i run 23 psi all the way...but forget to increase timing!...2 degree increase give's me knock
Not stock anymore
Old 07-24-2008, 02:37 PM   #19 (permalink)
ojcool's Avatar
Trader Rating: (12)
Yes, it is a pain in the ass, and one that is likely driving you pretty crazy having to drive the thing to work and back every day, gettting smoked by hondas no doubt..... I was going to say, just put another pound or two of boost on it for the time being, but 23 is as far as I would go with boost. Unless you can get that thing to hold more to redline. But I guess you are not seeing a whole lot of redline these days.... I'm just F'ing with you.
I won't be that hard to fix.
Are you still running the 180 degree stat? This is on a completely unrelated subject. Just wondering what you have tried to bring back fuel economy beyond putting in the stock stat.
I have a flash that I am quite certain will fix that.
Old 07-24-2008, 02:44 PM   #20 (permalink)
I am just running the stage 3 torque table right now and that's what it's run. I haven't modified the torque table yet because I need to get the damn fuel right first. I have a tune in right now that's way off, but it works and I can actually ride it out to 6500... AFR are low tens to less then ten at WOT... But that's fine for now. I just want to get the fueling right. That's my main concern right now. The car is still faster then when I had the E1 and meth LOL... Still running the 180* stat. Fuel eco will be fine once it's fully tuned.
Old 07-24-2008, 03:22 PM   #21 (permalink)
ojcool's Avatar
Trader Rating: (12)
Did you cut and paste the stage III torque table to the stage II tune?
Old 07-24-2008, 03:49 PM   #22 (permalink)
Member Number: 48080
For me, scaling for 750's nailed idle, part throttle, and cruising (all fuel trims stay very close to 0), but left me rich at WOT. I just removed fuel for WOT through the VE Bank 1 table based on my wideband logs at the track. IIRC I pulled about 20% from 3000rpm on up to get it from pegged at 10:1 to a nice flat 11.5:1 at WOT.
There may be a better way to do it, but that's what worked for me. Then again, I have a unique vehicle that I'm tuning here.
One of a kind custom turbocharged 2004 Chrysler Sebring LX Sedan
.:CarDomain:.
SebringLX is offline   Reply With Quote
Old 07-24-2008, 04:24 PM   #23 (permalink)
It's the Stage 0 tune, totally re-worked. Cut and pasted and then some... Some of the stuff I had to manually rescale.... Some of the stuff you can't cut and paste. You have to actually just re-write it manually.
Old 07-24-2008, 04:46 PM   #24 (permalink)
I am going to try and get the injectors closer... Then I think I will pop it out the VE table... Thanks for the heads up.
Old 07-26-2008, 10:54 AM   #25 (permalink)
Super Moderator
Nick Fury's Avatar
Member Number: 19761
In case you need it, heres the calculator:
Injector Flow Conversion Calculator by NickFury
Scaling the injectors properly made a world of difference for me, I'm also not running a RRFPR.
Need Boost
Nick Fury is offline   Reply With Quote
Old 07-26-2008, 05:10 PM   #26 (permalink)
thank you. That's how I calculated it, but I am just having a hard time getting it nailed for some odd reason. I think the injectors I have flow totally different then the stock molar injectors. I also think from the factory and in the staged kits that the fuel trims are off.
Old 07-26-2008, 10:47 PM   #27 (permalink)
that's a question i am wondering to
because the VE of S0 and S2 are different...if i understand correctly
they should be the same since you didn't change anything to the engine
Old 07-26-2008, 11:26 PM   #28 (permalink)
wannasupra's Avatar
Member Number: 32741
from the factory the stage kits run rich as snot. i was pegging 10:1 or richer with my S2.
"Scoff not at my vile remarks horny fiend"
Quote: Originally Posted by Sweets View Post
^^ Im with supra..
Old 07-28-2008, 08:48 AM   #29 (permalink)
Running the S2 VE Table I was fine for idle and part throttle with the injectors scaled, but WOT was very rich like wannasupra said, pegged 10:1 until I removed 20% from about 3000RPM on up from the VE table. After that a nice smooth 11.5:1.
I re-tuned and was hitting 22psi all day yesterday doing some autocross. Still need to make some adjustments, dropping just under 11:1 in the lower boost range then hitting 12:1 at the spike before dropping back to 11.5:1. I disabled the coasting fuel shut-off, made for some fast fun autocross.
I am having a strange problem though. Whenever I flash a new tune, it is very hard to start the car again the first time after a flash. It's like it dumps a ton of fuel in and floods it. Takes me 10 to 15 minutes to get the car started up after a flash. Then every time after that, it starts perfectly. Fuel trims at idle are always right around 0 after starting it up, so it doesn't make sense. Out of the dozens of vehicles I've tuned, I've only ever had this problem on this car. :\
Old 07-28-2008, 11:00 AM   #30 (permalink)
Member Number: 18641
Do you disconnect the battery after you run your flash?
Splitz is offline   Reply With Quote
