I dont think you can copy entire VE tables between codes . For example , stage 2 injector vs. fuel charge tables have many more cells than the stage0 equivalent . it has a higher resolution & much more top end headroom . Im willing to bet that the stage two has more headroom due to the extra 10+ psi available with the 3bar setup . at one point I was running a stage0 code converted to 3bar . to do this I had to transfer my stage2 injector scaling for my RC650cc injectors & convert it to the stage0 tables . I decided to leave the pwm side of the tables alone and just messed with the fuel charge side . Some pwm points were the same , most were not , stage0 stopped at 35,000 microseconds , stage2 at 100,000 micros . there is two ways to figure out the math to rescale new flow at different pulse-width points . determine the difference between old/new pwm points & multiply new fuel charge scale by that amount . for example , if stage0 table has its first pwm point of 500 micros , but the stage two is at 600 , you would take your stage two fuelcharge amount at the first point & multiply by .833 (500 divided by 600) to get is fuel charge value at a 500 micro point .
The other , less accurate way involves of graph paper , plot out both tabes onto large graph then draw lines from stage0 points into stage2 fuel-flow curve at that point . I may not be explaining this well . its easier to show than type .
My example deals with injector scaling , but the concept is the same for scaling/offsetting VE tables .
Im self taught , other than help I get here , so my methods may be ass backwards , but it seems to work . See , your teacher was right when she said "someday you will wish you paid attention in math class ."
