flashing stock pcm to staged with prp - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-09-2010, 01:39 AM   #1 (permalink)
buzzkill's Avatar
Member Number: 38178
Default flashing stock pcm to staged with prp
since i cant seem to get in on sct's forums prp section yet, i might as well ask you guys. I know that i can flash my stocker to any staged pcm, but what is the procedure for doing so? YES, i am very new to sct's prp (like one day into it) and still getting familiar but wanna start with a diff stage tune and work from there. anyone wanna help the newest prp newb out?
R.I.Pieces delta 46 (800 miles.......MANY MANY pieces!)ZETA 3.0 SURPRISE SURPRISE , 30R installed now and couldnt be happier , Meth, And a train horn. what else ya need?
Bow to the Mullet. :
SOMETHING IS ABOUT TO HAPPEN......
buzzkill is offline   Reply With Quote
Old 01-09-2010, 07:28 AM   #2 (permalink)
apexcrazy's Avatar
Member Number: 24279
Once your PRP is unlocked , when you open the Advantage software it will ask you what PCM code you want to open . Enter a stage code# , you should have 1 or 2 codes available to you , right ? the guy at SCT should have had that disscision with you when they enabled your software .
The SCT Wiki has a list of most of the stage-codes available for the SCT PRP . Enter the code you are going to use and the software should finish opening .
The code Im using , for example , is the 04 stage2 code .
04510850AA
When you install a stage2 flash , you MUST have the 3-bar MAP & TIP sensors installed , & larger injectors . If you are not using Mopar stage2 injectors , you must rescale your PWM vs. Fuel charge table & its inverse table , Fuel charge vs. PWM table to match the flow characteristics of the new injectors . This is explained in the SCT Wiki (injector rescale page) , as well as it has a calculator application to help you out .
S3 turbo/mani,S3 coilovers,SCT PRP,1025cc inj,AGP Race,N2MBWOTBox,ACT HD-Street,Hurst,Needswings
apexcrazy is offline   Reply With Quote
Old 01-10-2010, 06:55 AM   #3 (permalink)
duster360's Avatar
Member Number: 45182
And if you don't have 3bar sensors to go with with the S2 code, just change the Map slope back to stock.
Stock Map slope: 46.38
S2/S3 Map slope: 61.85
1025cc Injectors+ E85/GAS Base tunes =$359
ADD Boost By Gear to ANY PCM boost control tune $75
E85+Gas Base tune Combo $150*[*Only available for 1025cc Siemens/FIC1100&2150/AGP1200/All ID]
PLEASE USE EMAIL!!dave at needlesstorque dot com
Old 01-10-2010, 06:11 PM   #4 (permalink)
buzzkill's Avatar
got 3 bar already but im gonna write those numbers down just in case they are needed in the future for some reason.
Old 01-10-2010, 07:59 PM   #5 (permalink)
buzzkill's Avatar
Hey guys, these are my mods:
stock pcm
E1 (24 psi)
boomba bov (no leaks, believe me, i checked)
mopar 3" cai
agp hardpipes
custom built griffin core bfmic
freshly rebuilt mpx 62 mm tb
fbm ported intake mani (before they went to shit)
rc 650cc inj
150 psi pump coolingmist trunkmount with m8 nozzle (100% meth)
FM wga
ptp ported ex mani
3" maxxfab o2 housing
3" catless turbo back exhaust
agp solid mm's
bwoody solid trans mount
n2mb wot box w/ 2 step
Stock clutch (but act six puck is sitting in garage waiting to be installed)
3 bar sensors
15 BIG decals (cause those each add AT LEAST 15 hp)
might be some i forgot, but i'll add as i remember
do you agree that the stage two base flash would be the best to start with when tuning with my mods?
Old 01-11-2010, 12:01 AM   #6 (permalink)
starvin's Avatar
Member Number: 18192
Wideband!!!
2005 Black SRT
just a bunch of used parts I bought and slapped on haphazardly.
Iceman TB, XS POWER intercooler, AGP coldside and intake, Driver mod, 3" O2 and downpipe, 3" CAT, RC 750's,TurboXS RFL, STG 2 WG, and an sct thingy..
starvin is offline   Reply With Quote
Old 01-11-2010, 05:29 AM   #7 (permalink)
buzzkill's Avatar
Told told I'd forget some stuff. Aem wideband on the car also. Anything else you see missing? Prolly got it just forgot to write it down.
Old 01-11-2010, 05:31 AM   #8 (permalink)
buzzkill's Avatar
30/30 boost gauge and scan gauge also
Old 01-13-2010, 01:39 PM   #9 (permalink)
buzzkill's Avatar
stage 2 code has been unlocked for me by sct. Now i am trying to build a tune but will prolly have a lot of ?'s for you guys. I have loaded the stage two code into advantage and rescaled the inj tables (both of them) for my rc 650's.
now i need a little advice on what i should look at next. Is there a specific order I need to go in when changing tables?
Oh, also i have seen a lot of complaints on here about cs at sct regarding contacting them and having to wait on hold forever to get someone to help you. Well I think (at least the two times i tried this) that I have found a better way. Try getting online and using their online tech support. both times I waited less than two minutes for someone to help me and got both issues resolved in less than five additional minutes. Hope this helps someone out.
Old 01-13-2010, 09:08 PM   #10 (permalink)
buzzkill's Avatar
anyone wanna shed some light on the tuning basics? i.e. how to save a file, what order to customize a file, etc.?
One place SCT fell short on was a manual.
Old 01-13-2010, 09:14 PM   #11 (permalink)
Vendor
nemiro's Avatar
Member Number: 32732
there is/was a wiki that answers most all of your questions.
Neil Emiro - SCT & DiabloSport Tuning / TCS: DriverMod
ND Performance ∙ Since 1996 ∙ PM me with all of your tuning and electronic traction control needs!
"No one has more turbo Dodge calibration experience, this side of the factory"
Old 01-13-2010, 09:19 PM   #12 (permalink)
buzzkill's Avatar
Yeah i read so much that i cant make heads or tails of it now, my eyes hurt. but i did read the wiki, just not sure how to compensate for extra air flow (VE table, correct?) from 24 psi E1, and large intercooler, 62mm tb, and such, blah blah blah. a little overwhelming right now but hopefully it'll get better. Thats how we all learned, right? I'm pretty sure no one popped out of the womb tuning cars.
Old 01-13-2010, 09:55 PM   #13 (permalink)
starvin's Avatar
well if you have not pulled all the vac lines start there with some boost control. Read the "Desired torque" page to understand what it does, then start doing the procedure on the "Boost control" page. You will want to do EXACTLY as the wiki states so that you have a nice smooth boost curve. This will get your feet wet for now I am sure. also try using a couple small stickers. (especially all lined up in a column at the edge of the front door.) i hear that this helps with some drivability issues and will make your MPG go up.
2005 Black SRT
Old 01-13-2010, 10:19 PM   #14 (permalink)
buzzkill's Avatar
yeah apparently from what i've read stickers are the shit. lol
but seriously, the sections in the wiki you are talking about are for pcm controlled boost right? I'd rather keep it that way instead of yanking it all off and going manual boost control.
Let me know
Old 01-14-2010, 10:03 AM   #15 (permalink)
buzzkill's Avatar
I'm gonna start by using the base stage two code and adjust for inj size. Then i am going to adjust boost control (per the wiki) to get to my desired level. Once i am done with that i will report back.
I am a little nervous about doing that though because i have not altered the timing table yet, but I am assuming the timing for the stage two pcm should be at a safe level to start. then I can fool with that later right? And also fuel.
Is it correct to do these two steps first? (inj and boost)
