Old 10-05-2009, 05:35 PM   #1 (permalink)
apexcrazy's Avatar
Member Number: 24279
Default external wastegate control w/PRP ?
I have a chance to pick up a PTP intimidator maifold w/external gate , flapper removed & filled in .
My question is , will the ecu boost control work with an external wastegate ?
I am assuming the larger diaphram , chamber volume , & spring differences will require changes to the related tables .
Anybody have any luck with this ? If I cant control the boost with the ECU when using an external wastegate , ill have to pass on this deal .
_____ _____
apexcrazy is offline   Reply With Quote
Old 10-05-2009, 05:40 PM   #2 (permalink)
Colin1337's Avatar
Member Number: 55514
dude dont pass up on it. get it, and buy a MBC for $60 on ebay or used. problem solved.
2005 SRT-4
Stock PCM, DSP w/PTP canned tune, FW WGA, ED SEE, BFMIC, Mopar Rice Plate, Injen SRI, DCR 180 thermo, Granatelli Plug Wires, 4306 NGK plugs, V-band exhaust manifold.
Soon to come:
PTP S3K and supporting fuel mods
Colin1337 is offline   Reply With Quote
Old 10-05-2009, 06:01 PM   #3 (permalink)
apexcrazy's Avatar
I know , but I really like the advantages of the ECU controlling all aspects of my tune , The boost by gear , the overboost protection , ect .
This is my daily driver , in the snow as well , so I change flashes according to the weather , or how much ethanol in the mix . I would hate to have to keep track of wether the boost is right for the flash Im on , or accidently run too much boost for the flash Im on .
I had planned on a stage 3 turbofold/turbo in the future because it could be controlled via ECU , I have seen a group by of $1500 for the set .
However , with this deal , I could get a Intimidator , external WGA , dump tube & new S3K for half the price .
Im torn between the two choices .
Old 10-05-2009, 06:56 PM   #4 (permalink)
Member Number: 69186
Trader Rating: (10)
You can use the ext wastegate. Plug the vac line from the stock solenoid into the bottom of the wastegate. Might take a little tunning to get your boost where you want but it will work fine.
DoodEdge is offline   Reply With Quote
Old 10-05-2009, 08:43 PM   #5 (permalink)
nemiro's Avatar
Member Number: 32732
Trader Rating: (165)
I use PCM boost control with my externally gated DCR 47# S3, and it is indeed my daily driver.
Neil Emiro
2005 Dodge SRT-4
Old 10-05-2009, 08:46 PM   #6 (permalink)
Colin1337's Avatar
do you know where theres a diagram for this?
i have been meaning to start messing with vacuum lines, but i havnt been able to find one for external gate w/pcm control
Old 10-05-2009, 08:55 PM   #7 (permalink)
Trader Rating: (10)
realtune has some good vac diagrams under there vendor section
Old 10-05-2009, 08:59 PM   #8 (permalink)
Colin1337's Avatar
ill check it out. thanks
Old 10-06-2009, 06:35 AM   #9 (permalink)
apexcrazy's Avatar
Thank you , guys .
Old 10-08-2009, 09:07 PM   #10 (permalink)
Member Number: 31650
it's very simple you just do like stated before
you use the black line connected to the stock WG
and plugged in the lower nipple of an external WG and bingo you are done
Not stock anymore
Page generated in 0.14985 seconds with 13 queries
