Old 03-19-2009, 08:34 PM   #1 (permalink)
julius717's Avatar
Member Number: 24352
Default Ecu Unlock Fail Help!
got home plugged in my scanner to load my map and now my ecu is locked and my car wont start. how in the hell do i fix this? i have had nothing but problems witht his bullshit ass program since i started to use it. and now my car is fried/
DRASTIC
julius717 is offline   Reply With Quote
Old 03-19-2009, 10:32 PM   #2 (permalink)
nemiro's Avatar
Member Number: 32732
Trader Rating: (165)
If you pulled the connector out, or turned the key off during programming, then the PCM is pretty much blank. Call SCT, and they can help you. Advantage is a buggy software suite, but I have been using it close to two years now with good results.
Neil Emiro
2005 Dodge SRT-4
Old 03-20-2009, 02:48 AM   #3 (permalink)
julius717's Avatar
none of that happend. all i did was hit load tune it was doing the powering down all was well then it just said ECU ERROR and stopped. hopefully they can fix it over the phone/computer i cant have my car down past the weekend
Old 03-20-2009, 08:20 AM   #4 (permalink)
04blusrt_4's Avatar
Member Number: 60369
Didnt it ask to return to stock? You should have said "yes" and then let it reload the stock file, then you could have tried again to reupload the new tune.
*NE 400 Club*
Old 03-20-2009, 10:57 AM   #5 (permalink)
julius717's Avatar
yes it does but since it failed out half way through the first time it didnt completly back up the stock file so now my ECU is blank. i have been on the phone with SCT for about 45mins they are trying to figure it out
Old 03-21-2009, 11:42 PM   #6 (permalink)
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
Hope you get it figured out. Any electrical work on the car? Had a friend that had some wiring that had a bad ground....ended up bricking 3 pcms before I brought over a volt meter and tested everything.
Old 03-22-2009, 12:51 AM   #7 (permalink)
apexcrazy's Avatar
Member Number: 24279
about a year ago my Xcal developed a short where the cable enters the handheld . it gave up during a flash . since the obdII port was , at that moment , ready to download data into ecu . Dealer replaced XcalII But that didnt work . All I got was "error 11 non-autodetect obd port" or somting like that . In the end I had to send ECU to SCT and they fixed it ! Now I treat my handheld like a jewel .
_____ _____
apexcrazy is offline   Reply With Quote
Old 03-22-2009, 01:48 PM   #8 (permalink)
nemiro's Avatar
Very good advice.
Old 03-22-2009, 08:36 PM   #9 (permalink)
Mana4real's Avatar
Member Number: 25021
I know it sucks dude. We talked about this. I told you I would help you once it's fixed. Can you take it to the dealer and have them flash a program on it? It might cost you a little bit, but you would have it faster. Anyone know if he can take it to the dealer to have it flashed, meaning just the PCM or send it to flight systems?
-Matt- -SCT Tuned- By Yours Truely
Old 03-22-2009, 10:47 PM   #10 (permalink)
nemiro's Avatar
Dealer will more than likely not know how to flash it. Three options. 1. SCT; 2. Flight Systems; 3. Get another S0 PCM, and have your VIN flashed into it.
Old 03-23-2009, 12:48 PM   #11 (permalink)
Mana4real's Avatar
Thanks for clearing that up.
Old 03-23-2009, 12:54 PM   #12 (permalink)
Member Number: 64760
Trader Rating: (20)
someone is sellin an 04pcm for 25shipped in the FS section..
91PumpKing. is offline   Reply With Quote
Old 03-23-2009, 01:04 PM   #13 (permalink)
Senior Moderator
STUDLEE's Avatar
Member Number: 54852
http://www.srtforums.com/forums/f27/...-parts-482753/ <--- $75 for ECU
"In about three years, holla at me Miley Cirus!"
STUDLEE is offline   Reply With Quote
Old 03-24-2009, 02:09 PM   #14 (permalink)
SRTie4k's Avatar
Member Number: 45499
Trader Rating: (53)
It's entirely possible your ECU is just locked out. Similar thing happened to me except i got all the way through a flash, then my car wouldn't start, pump didn't prime, red alarm LED on dash stayed lit.
I finally had to send the whole ECU to SCT and they fixed it.
2008 Mazdaspeed 3
- Cobb SRI, Short Shift Plate, SU Solid Shifter Bushings, 18x8 Konig Runaway's
2008 Kawasaki Z1000
- Laser X-Treme Exhaust, -1 Front Sprocket, Speedohealer, Renthal Ultra-Low Bar, CRG Bar End Mirrors, Pazzo Levers, Motovation Frame Sliders, Targa Fender Eliminator, OEM Rear Cowl
2001 Kawasaki Ninja 250
- For sale soon...
Old 04-08-2009, 02:11 PM   #15 (permalink)
julius717's Avatar
So SCT just called me and is trying to charge me 65$ because my handheld is out of changes. which i find very interesting considering i had already been tunning my car with it hmmm..... WTF!!!!
Page generated in 0.19789 seconds with 13 queries
