Old 05-08-2008, 10:12 AM   #1 (permalink)
Member Number: 60912
Default Data Acquisition
Opinions wanted on what to buy for data logging & wideband. What do you guys think is best?
Innovative OT-1 and LC-1?
Aeroforce?
Hexalogger?
Something else?
I like the idea of being able to graph logs to aid with tuning PRP so that pretty much eliminates the last 2 options. Anyway, ideas and opinions?
Thanks!
SinCitySRT is offline   Reply With Quote
Old 05-08-2008, 11:29 AM   #2 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
Quote: Originally Posted by SinCitySRT View Post
Opinions wanted on what to buy for data logging / wideband. What do you guys think is best?
Aeroforce?
Hexalogger?
Something else?
Thanks!
I am crossing fingers they will have datalogging capabilities soon.
Shop hours are 10am to 7pm Mon-Fri
Taking calls on Tuesdays and Thursdays
Old 05-08-2008, 04:02 PM   #3 (permalink)
Member Number: 11814
Trader Rating: (91)
If you need a wideband and would like to also datalog some info then I would take a serious look at the Zeitronix
Zeitronix
I also think the Aeroforce is a good buy and wideband and Aeroforce gauge would be smart if playing with tuning and such.......but both at the same time can be some $$
I have 2 used Zeitronix setups F/S if interested. Both are setup to use palm5 for display and logging. I could sell the base one for $200 shipped, the other one with all options $300 shipped.
Old 05-08-2008, 11:32 PM   #4 (permalink)
Zeitronix
Don't want to invest in a palm pilot. Seems similar to the innovate products though.
That would be nice, but until then??
Old 05-09-2008, 05:24 AM   #5 (permalink)
Trader Rating: (91)
Palm5, palm software for the PC hookup, cables for charging hook up to the PC and to the Zeitronix, pocket logger for Zeitronix... all included......just letting you know.
Old 05-09-2008, 09:39 AM   #6 (permalink)
Technical Tuning & EFI/EMS Electronics moderator
sour kraut's Avatar
Member Number: 19796
Most people over look the dynojet wideband commander. Yes, it is more expensive, but the software is very easy to use and the inputs and outputs are easily configurable.
sour kraut is offline   Reply With Quote
Old 05-09-2008, 04:27 PM   #7 (permalink)
I changed my original post since I wasn't clear that I wanted to log OBD data and wideband. The Zeitronix seems interesting; what pids does it have available? Anyone have any input on the innovative? I know the innovative doesn't have a knock pid, but that seems like a non-issue since it will capture total timing.
Thanks
Old 05-09-2008, 04:30 PM   #8 (permalink)
Trader Rating: (91)
Theres a link to the Zeitronix site in my #3 post for more info on the Zeitronix.
Old 05-09-2008, 11:41 PM   #9 (permalink)
Member Number: 31650
i have the innovate ot-1 and lc-1
i work fine...when it's all setuped..(was a bit hard at the beginning)
and you need to have access to you serial wire of the lc-1(mine was installed a while back so ot-1 was not in my mind then)
and i have 2 aeroforce gage..ok it's good but not as good as the ot-1
but dam i would like to datalog all the value of the aeroforce on my computer
Not stock anymore
Old 05-10-2008, 10:40 AM   #10 (permalink)
I have been leaning towards the Innovative route. I was thinking about adding an SSI-4 and running the knock sensor to it? If that works then it should be easy to compare knock voltage to total timing in Logworks to figure out what the PCM is thinking.
Old 05-10-2008, 11:40 AM   #11 (permalink)
the probleme is that knock voltage does not really equal knock
the knock voltage is filterd by the ecu
i havent experienced for my self...but i have heard..mostly read that even with just the timing signal is obvious when you have knock
Page generated in 0.25012 seconds with 11 queries
