i got copy of powerpaq software from someone yesterday.. used serial to usb adapter.. when i hooked it up to car the program said something about tune is protect click to load one.. so i do that and it earsed everything on my powerpaq on car..
so i redid map all numbers for pullin fuel r the same and rpm scale the same..
but car wont idle or run.. throws some sensor codes now..
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
P0339-crankshaft Position Sensor Intermittent
P0344: Camshaft Position Sensor Intermittent
dont know if there some other option on power paq i dont know about..
that mess with timin.. cuz i dont have it pullin any timin on ignition map..
are these def from powerpaq map? or could it be coincidence and maybe at idle cam chain jumped a tooth or 2.. or sensor went bad from surge of power or something..
also program was gettin good smooth connection seem to go offline alot.. but was too late when i noticed this..
help.. my laptop doesnt work what i use to use to tune.. has my original map on there..
anyone with 50trim, 750cc inj, returnline, 3"TBE got powerpaq map??
i need HELP
