Old 06-15-2008, 09:43 PM   #121 (permalink)
Nick Chestnut's Avatar
Member Number: 16791
Quote: Originally Posted by nemiro View Post
Adding fuel would make the cat even hotter, so no enrichment.
That would be my thought... So what does the "Max Enrichment for Over Temp" scalar do then? I have seen reports of people having to disable this to prevent the PCM from dumping excessive fuel thought I haven't tested it myself.
- Nick Chestnut
* 2004 Dodge SRT-4, GT3076R, SCT Tune, 408 WHP w/o SCT and waiting on new numbers with SCT!
"Don't argue with an idiot. They bring you down to their level and beat you with experience." - Unknown
Nick Chestnut is offline   Reply With Quote
Old 06-17-2008, 02:05 PM   #122 (permalink)
RedSRT4Me's Avatar
Member Number: 402
A clogged cat would cause a huge loss of power. Definately get that checked out.
Also have you done a boost leak on this car after all the mods are installed?
Your TQ curve looks horrible for a DBB 50 trim. Your peak should be way before 4000 rpms. It looks like your not hitting full boost till after 4200.
RedSRT4Me is offline   Reply With Quote
Old 07-02-2008, 07:30 AM   #123 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (17)
For anyone interested I am still working on this issue. I'd sure like to know if anyone else has had good results with the SCT on a 2005 big turbo car revving over 6500RPMs. When/if the SCT ever gets programmed I will post up the results.
HCCAFan is offline   Reply With Quote
Old 07-02-2008, 08:12 AM   #124 (permalink)
Member Number: 48080
I thought your issue was you started having problems around 5200rpms? Did you get that taken care of and now the problem is over 6500 or what?
One of a kind custom turbocharged 2004 Chrysler Sebring LX Sedan
.:CarDomain:.
SebringLX is offline   Reply With Quote
Old 07-02-2008, 02:14 PM   #125 (permalink)
Technical Tuning & EFI/EMS Electronics moderator
sour kraut's Avatar
Member Number: 19796
can you send me the tune and logs so i can take a look??
sour kraut is offline   Reply With Quote
Old 07-02-2008, 05:38 PM   #126 (permalink)
HCCAFan's Avatar
Trader Rating: (17)
Heh, I can send you the tunes that are a while back but not the new ones. They are protected by Nemiro.
Old 07-02-2008, 05:40 PM   #127 (permalink)
HCCAFan's Avatar
Trader Rating: (17)
LOL man. I will PM you. Basically for anyone following this....
Ah fuck it.
My problem currently is the misfire code is back and I'm throwing the P2074 code. The misfire is caused by this code or is related to it. I don't care what anyone says. I know it's related.
Edit: The misfire starts around redline. Reason I havent even bothered changing the bolded edit on the first page.
Old 07-18-2008, 10:40 PM   #128 (permalink)
HCCAFan's Avatar
Trader Rating: (17)
Solved!
Finally other people had the P2074 code issues. It seemed to affect my car differently but basically any time I had a 2005 tune the car could and would throw the P2074 code while part throttle boosting. Something about this made my car show a miss on cylinder #1 under WOT which would set the CEL flashing and severely limit power. I also had the issue with the car cutting power and dumping fuel at the end of a pull through third and upon shifting to 4th would still have reduced power with A/Fs at 10.0 or lower.
Old 07-18-2008, 10:48 PM   #129 (permalink)
SRToc Member
Member Number: 25892
Quote: Originally Posted by HCCAFan View Post
Solved!
Is this something that was in the tune that was causing that or something mechanical actually wrong, like a coil or sensor?
www.bwoodyperformance.com
Mods: AGP GT3076R DBB Turbo
madwax is offline   Reply With Quote
Old 07-19-2008, 07:30 AM   #130 (permalink)
HCCAFan's Avatar
Trader Rating: (17)
It was in the tune.
With the tune Nemiro made for me the car will not throw the P2074 code anymore while part throttle boosting. This also means that the car will not show a miss on cylinder #1 in the higher RPMs. I don't think anyone knows why my car does this but I am sure others will. Mind you the car would throw P0300 and 0301 codes but mostly I was watching the miss on the Solus scan tool. Now that my car has a modified stock 2004 tune it does not throw any codes and pulls well past redline. I have no idea what P2074 has to do with making the car miss but it does.
Old 07-19-2008, 01:53 PM   #131 (permalink)
Member Number: 25021
Glad it's finally fixed. I know you have been working with this forever.
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Old 07-19-2008, 02:53 PM   #132 (permalink)
HCCAFan's Avatar
Trader Rating: (17)
Thanks! Me too!
Old 07-20-2008, 03:04 AM   #133 (permalink)
wannasupra's Avatar
Member Number: 32741
wow, props to nemiro then. so when do we get to see a vid on the street of you winding that beast to 7k?
"Scoff not at my vile remarks horny fiend"
Quote: Originally Posted by unnecessary View Post
Son Of A Bitch!@#!#@@#! You made me hit my Knee on the desk!
Old 07-20-2008, 12:16 PM   #134 (permalink)
HCCAFan's Avatar
Trader Rating: (17)
My rev limit is 6700. But anytime I suppose. I may have a video or 2 to post after this coming Tuesday anyway.
Old 07-21-2008, 01:15 AM   #135 (permalink)
wannasupra's Avatar
word. post a link in here. maybe on the first page, so noobers don't have to read the whole thing. wait, n00bs don't really come in here that much.
