Old 03-19-2008, 02:22 PM   #31 (permalink)
DrmCtchr's Avatar
Member Number: 38971
Quote: Originally Posted by TehDeF View Post
Just out of stupid curiosity. Can you use the SCT features to bypass CEL's? In a manner that say... and OBDII test would not find?
Feel free to PM me the answer, as I will probably forget to return here.
I guess you need to provide more detail. your question is similar to ... "Is chocolate cake good with liquid refreshment"? The initial answer is yes chocolate cake is good with certain types of liquid .... puke for instance is not a great liquid to eat with chocolate cake.
D
DrmCtchr is offline   Reply With Quote
Old 03-20-2008, 12:25 AM   #32 (permalink)
Member Number: 27420
More specifically?
No Cat and Overboost CEL's. I dont want to have to fix these damn things by getting s1 and a new cat.
null.
TehDeF is offline   Reply With Quote
Old 03-20-2008, 06:29 AM   #33 (permalink)
Member Number: 52496
More specifically?
Yes they can be disabled. Whether or not you can pass without a Cat depends on the type of emissions test used.
SCTSRT4 is offline   Reply With Quote
Old 03-20-2008, 08:25 PM   #34 (permalink)
Oh I have a cat, I just want to pass inspection by having the tune mask these issues.
Old 07-19-2008, 03:33 PM   #35 (permalink)
Member Number: 61737
Can overboost be modified with the prp
agmastakilla is offline   Reply With Quote
Old 07-19-2008, 06:09 PM   #36 (permalink)
Member Number: 31650
the setting can be change
and the code can be switched off
Not stock anymore
Old 08-25-2008, 01:45 PM   #37 (permalink)
Member Number: 44696
Trader Rating: (17)
What would be cool is update the Parameters to provide a brief description of what each does. As we learn more about the parameters we all can help to update to make this thread more useful.
WOT Spark - Your main adjustment to adjust spark
VE Bank 1 - Your main adjustment for volumetric efficiency. (Fuel adjustment)
VE Bank 2 - Not used
Rev in gear - Not really used because with a manual trans it thinks it is always in neutral
Rev in neutral - Main adjustment for Rev limit. Adjust both in gear and neutral to the same
Anyway you get the point...
Perrin FMIC and fuel rail, AGP Wastegate, 50 Trim turbo, ported tb,Bwoody MM, PTP CV, BDJ 3" Exhaust, CAI 3" JMB, 160 Stat, BDJ Heatshield, iridium plugs w/msd 8.5mm, Mopar STS, Redstar return fuel system, Innovate WB.
Best 12.34 @118 MPH on bad traction gunning for 11'S on SST turbo.
New setup has not been tracked yet
Street Gear is offline   Reply With Quote
Old 08-26-2008, 06:57 AM   #38 (permalink)
There are descriptions in the software for some parameters now, and the file is being worked on currently to include more and better descriptions. Thanks for the input.
Page generated in 0.15099 seconds with 11 queries
