Old 06-19-2008, 08:07 AM   #31 (permalink)
Member Number: 31622
Quote: Originally Posted by 2Spools View Post
93 pump gas with washer fluid and heet
Umm... The Heet I can see if you think you have a problem with water in the system, but why in the world would you put washer fluid in your gas?
'05 SRT-4
'87 Turbo-T
Got Boost?!
CaptainInsane-O is offline   Reply With Quote
Old 06-19-2008, 09:06 AM   #32 (permalink)
ojcool's Avatar
Member Number: 19382
Trader Rating: (13)
Quote: Originally Posted by JANNETTYRACING View Post
Here is the dyno sheet it actually made 397 hp 433 tq.
Attachment 39162
Now, was that car anywhere close to being out of fuel Ted?
Every human being is ignorant, only on different subjects.
ojcool is offline   Reply With Quote
Old 06-19-2008, 09:08 AM   #33 (permalink)
ojcool's Avatar
Trader Rating: (13)
Hes injecting it via water injection, heet is 100% methanol.
Old 06-19-2008, 10:33 AM   #34 (permalink)
OK, in the alky injection makes a lot more sense...
I'm well versed with their use on Turbo Buicks, but the washer fluid thing is still new to me; if you wanna go cheap, just go to walgreens & run either 70 or 92% IPA with the HEET. That way you don't have the surfactants & blue dye running into the combustion chamber.
Old 06-19-2008, 11:10 AM   #35 (permalink)
JANNETTYRACING's Avatar
Member Number: 10982
The mixture of Washer fluid and Heat are injected in the charge pipe via a Water Meth kit.
Ted.
JANNETTYRACING is online now   Reply With Quote
Old 06-19-2008, 11:12 AM   #36 (permalink)
No with the boost referenced Regulator and 255 in the tank it is real good I can make it a full point richer if I want.
It did run out of injector with static fuel pressure only.
Ted.
Old 09-22-2008, 04:30 PM   #37 (permalink)
2Spools's Avatar
Member Number: 18960
Trader Rating: (17)
*UPDATE*Just recently been to the track with this setup! Drove 1.5 hours there put on my slicks ran 4 passes.First pass blazed the tires into 3rd and went 12.2 ,2nd went 11.65,3rd 11.60 4th and final 11.58. Every pass was at 124 mph.Changed tires and drove it home. This is the same setup as I originally posted but on the race gas tune and a 50/50 mix of 104 and 93 car was 3/4 full.All runs were at 25.5psi.
Stage3/Stage0 11.58@124 JANNETTY RACING SCT TUNED
www.turboaddictionparts.com
2Spools is offline   Reply With Quote
Old 09-22-2008, 06:33 PM   #38 (permalink)
ayoungblood's Avatar
Member Number: 7132
Trader Rating: (15)
Nice!!!!
2k4 Srt-4 -- Stock
ayoungblood is offline   Reply With Quote
Old 09-22-2008, 08:02 PM   #39 (permalink)
lphooper03's Avatar
Member Number: 37050
That's quick bro.. Very nice numbers. Are you going to be keeping this setup?
2003 Solar Yellow
Mods: AGP 50 Trim, 38mm Turbonetics WG, SAFC 2, Walbro 255, Centerforce Dual Friction, N2MB WOT Box/2-step, Ported TB/Spacer, UEGO, DW 650cc Injectors, LED Tails, Fuel Pump Rewire, Perrin STS, QW IC, Mxp Turboback, Injen SRI, AGP UHP w/Greddy S BOV (T-Bolts), Blitz TT, 30/30 Boost, Drop Springs, Black Stripes.
Coming Soon:W/I, Cams/Gears, Scan Guage
Old 09-22-2008, 09:50 PM   #40 (permalink)
2Spools's Avatar
Trader Rating: (17)
Thanks, yes I plan to keep the car how it is. This is more then fun to say the least on the street.
Old 09-25-2008, 07:20 AM   #41 (permalink)
Member Number: 60369
I saw the passes, dunno if you realized but you were spinning 1st hard off the line, not sure if thats what you want (saves axles, not like me when i snapped mine ), just an FYI.
What meth kit are you using? Does your car hang in HOM all the time?
s3 turbo, SCT prp, some giggle juice
Old 09-25-2008, 07:36 AM   #42 (permalink)
Just needs more tire and it will et much better, it has MPH for 10s
Ted.
Old 09-25-2008, 07:51 AM   #43 (permalink)
Ted.
Hey ted, i think im gonna ditch my N20 and go the meth route, better more reliable power, plus when HOM is on, its sick. Do you know what kit nick is using?
Old 09-25-2008, 07:57 AM   #44 (permalink)
Snow Performance, And I just happen to have one in stock
Old 09-25-2008, 08:03 AM   #45 (permalink)
Price?? Part #?
