Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Southwest
Old 10-11-2009, 08:26 PM   #16 (permalink)
Member Number: 3797
Didn't take too long. It took about as long to raise the car, change the oil and put it back on the ground as it did to do all the line hook ups and re-assembly. Took it for a spin, tweaked the WGA seems to run fine. Feels slow though...
enginjoe is offline   Reply With Quote
Old 10-12-2009, 03:43 PM   #17 (permalink)
Knerrbo's Avatar
Member Number: 58462
took it down tucsons mini highway, and did a 4th gear pull from 55 to ... well, im not gonna say. got some funny boost readings 17, 15, then 12, kinda hopped around. did a 3rd gear pull and got some better boost readings. the car was only holding 13.5 and spiking 18.5 with just under 11 on the wideband. so I've still got some room to play with it!
as for the E 2, im undecided if Im gonna keep it. probably gonna rebuild it and sell it for 650 (still not a bad price, since it will be rebuilt correctly this time)
and spend the money on the wot box and boost box. or I will just buy a dsp from agp and get unlimited tunes!
Knerrbo is offline   Reply With Quote
Old 10-12-2009, 08:32 PM   #18 (permalink)
Member Number: 52541
Quote: Originally Posted by Knerrbo View Post
[/b]
DSP would be your best bet
___________________________
2003 Solar Yellow - DSP, Meth & Boltons
dabezt1 is offline   Reply With Quote
Old 10-12-2009, 09:36 PM   #19 (permalink)
saucy5000's Avatar
Member Number: 61769
[/b]
Right on, glad you got everything working again. Does it feel faster than the E2 like you were thinking it might?
saucy5000 is online now   Reply With Quote
Old 10-13-2009, 12:03 AM   #20 (permalink)
Member Number: 3797
[/b]
Either your boost gauge is wrong or you have boost leaks. It should peak and then fall to the hold value. It shouldn't go up and down during a pull. I guess you could have fueling or spark issues too.
Old 10-13-2009, 11:02 AM   #21 (permalink)
Knerrbo's Avatar
yeah, Im thinking my boost gauge/controller might not be working or hooked up correctly because i get funny boost readings like that. 3rd gear wasnt giving me any issues though. spike 18, holding 13-14, then drops off to 11-12.
I probably have some fuel issues though. idk, ever since I've had the car I've never completely solved my boost issues though. Hopefully a DSP from AGP would solve that problem.
the car doesnt feel any faster than it was before, but it definitely is spooling up alot faster. I know the E2 wasnt working correctly because I wouldnt see full boost till 3400 rpm. this turbo I see full boost at 2800!
Page generated in 0.15390 seconds with 13 queries
