Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Southwest
Old 06-27-2009, 03:59 AM   #1 (permalink)
Magna_SRT's Avatar
Member Number: 73558
Default Lookin for a Stock NSRT motor
like the title says I am lookin for a stock motor with anywhere from 15000- 40000 miles that hasn't been abused my motor is getting high in the miles area and I don't know how well the guy that had my car before me took care of it. If you know any one in utah or somewhere close hit me up
Thanks, Steve
2004, Stage 1... plus a few other items!
if there is always someone giving their .02 cents and you give a person a penny for their thoughts where does the other penny go?
There are passangers and than there are drivers....... than there are SRT drivers who fly by them at 150
Magna_SRT is offline   Reply With Quote
Old 06-27-2009, 04:03 AM   #2 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Magna, eh? How's the water over there? LOL!
In all seriousness, I don't know of anyone getting rid of their stock motor at the moment. But if I hear of anyone, I'll let you know.
Why don't you do some simple tests on your motor to see how it's wearing? Do a compression test on it, and see how things are looking, maybe get an Oil Analysis done. They aren't too expensive, and will tell you a lot.
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Old 06-27-2009, 04:05 AM   #3 (permalink)
Magna_SRT's Avatar
well the water is ok if you like to chew it do you know where I can get all of this stuff done? I am really new to all this stuff.
Old 06-27-2009, 04:09 AM   #4 (permalink)
You can buy a compression tester from any parts store, and check it yourself. It's as easy as changing the spark plugs, really...
As for the Oil Analysis, go to Amsoil's website, and I believe they have a kit to make it very simple. You just get a sample of your oil during your next oil change, and send it in to them. They will then test it and send you the results.
Old 06-27-2009, 04:12 AM   #5 (permalink)
Magna_SRT's Avatar
ok sweet thanks... so how is your car running? have you taken it to rmr this year.
Old 06-27-2009, 04:19 AM   #6 (permalink)
I'm still waiting on DCR for some internals to finish up the build.
Old 06-27-2009, 04:23 AM   #7 (permalink)
Magna_SRT's Avatar
nice I heard you blew up the stock motor you were runnin but what hp are you lookin for with your new setup?
Old 06-27-2009, 04:26 AM   #8 (permalink)
Yeah, the stock motor still runs, but it has a bent rod in cyl # 4, so it has sat since that happened.
With the new build, I plan to max out the 37R, so somewhere in the 700hp range. Then I am toying with the idea of Nitrous on top of that. We'll see how it all pans out.
Old 06-27-2009, 04:31 AM   #9 (permalink)
Magna_SRT's Avatar
damn thats cool, I have been tryin to figure out what turbo I should go with I am lookin for stage3 kits but they are still like 4200 bucks from the dealership and so is the AMS kit online... what do you think I should do I only want like a max of 500 fwhp?
Old 06-27-2009, 04:43 AM   #10 (permalink)
Magna_SRT's Avatar
I only ask you because I hear people talk about you all the time lol!
Old 06-27-2009, 05:28 AM   #11 (permalink)
Member Number: 36825
Check out car-parts.com Nation junk yard search engine but can be $$.
SRT Jeff is offline   Reply With Quote
Old 06-27-2009, 06:28 AM   #12 (permalink)
Magna_SRT's Avatar
with your stock motor sittin around chuck would you be willing to part with it?
Old 06-27-2009, 12:54 PM   #13 (permalink)
Well, realistically, you need to consider what you are getting with the kit, when comparing prices from one setup to another.
With Mopar S3, you get everything you need to just install and go. No messing around with it. No worries about blowing the motor up. You are not only getting a turbo kit, but you are also getting a new fuel system that includes injectors, a new fuel rail, and a new fuel pump. You are also getting a new PCM that is calibrated perfectly for the turbo and fuel system, along with new sensors that will accurately measure boost up to 29 psi. But you'll never make 500 whp with that setup. About 400 is as good as it's gonna get with all the bolt-ons and tuning.
If you were to buy the AMS kit, (assuming you only went with the GT3076R turbo) you'd still need the following:
- Fuel system, to include larger diameter feed line, return line, Walbro 255 fuel pump (Possibly 2 pumps, either in series with each other, or parallel), high flow fuel rail, 750cc injectors, and a RRFPR.
- Tuning, don't even think about piggyback tuners. Look into either a DSP custom CMR tune, SCT PRP, or go full EMS.
- At least a 3 bar MAP sensor. This will have to be set up to work with the PCM via SCT or DSP; or set up in the EMS.
- Built motor to sustain all that power. (The stock bottom end will only get you so far at that power level.)
I'll be keeping that motor around. It's got a bent rod, and would not be able to be saved without at least boring it .020" over, and a full overhaul.
Page generated in 0.18085 seconds with 13 queries
