(Yes mods, this is in the right section...)
Here we go guys:
24.5" M&H slicks at 11 PSI on the left, 10 PSI on the right
Front coilovers at 6 clicks toward hard from max soft
Rear coilovers at 6 clicks toward soft from max hard
Boost was about 21 PSI max
100% Methanol in the tank, M5 in the intake and M7 in the TB spacer, meth comes on at 10 psi of boost @ 150 psi
91 octane gasoline (about 3/8 full)
DAB settings 0133 (if memory serves)
NO HOM
SAFC II was pulling out 15% fuel from 3000 to about 5600 RPM
Traction bars tightened as much as possible with wheels on the ground
2-step was at 4400 RPM
WOT shifting at ~5500 RPM
AFRs were a solid 11.0 flat
I did second gear burnouts holding the E-Brake with the methanol OFF.
What did all of that jazz net me? A top 60' of 1.7791, 1/8 ET of 8.1807@88.77 MPH
So far I do enjoy the 1/8th mile. It's much quicker and you go through fewer gears (crossing the beams on the top of 3rd). Overall it nets a much quicker experience where you can easily tell the difference with small changes done the car, mostly because there isn't a long top end to "make up" for launch or shift errors. I did get to guesstimate how hard I launched based on how much the sunroof cover opened. My best one was about 3".
Just as an interesting note, by tinkering with the coilover "soft/hard" levels I knocked off a 10th of a second from my 60' with the same tire pressure and no other changes. I did this on two back-back runs and the numbers matched up very closely, proving to me that having the front max soft and rear max hard is not an ideal setup.
Well there ya go my Tucsonan friends, hopefully something in there will be helpful for you!
CHECK OUT THE PICS HERE!!
There's about 7 pics of me in the above gallery. You can see some nice smokey burnouts and two shots of the slicks wrinkling up on the launch! Talk about good timing on the photographers part!
