MAPerformance Fuel Pumps and Regulators For SRT4!!!! - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > MAPerformance
Old 07-04-2012, 11:14 AM   #1 (permalink)
Member Number: 48589
Default MAPerformance Fuel Pumps and Regulators For SRT4!!!!
Walbro 255lph High Flow Fuel Pump
The Walbro in tank fuel pump is an essential upgrade for forced induction applications. This 255lph high pressure model has seen over 500whp in some applications!
MAP offers a this pump along with a kit to make installation a breeze, and all for just over $100!
Deatschwerks DW300 High Flow Fuel Pump
Introducing the highest flowing in-tank pump yet. Surpassing the competition 300LPH at a time. This pumps fits the same profile as a Walbro GSS342 for a simple drop-in installation.
As tested on our Lead Mechanic's 1G AWD DSM:
  • 2.3L MAP Built Stroker
  • Testing our new Dark Performance T4 Manifold / Comp Billet 6262 Turbo Kit
  • DeatschWerks 300lph in-tank pump and 1500cc injectors
  • Tuned on E85
We were able to make well over 600whp on E85 on just the single DW300, where a standard Walbro 255lph limited the car to just over 500hp.
FueLab Fuel Pressure Regulators and In-Line Fuel Pumps
FueLab 565 Series Fuel Pressure Regulator
FUELAB 565 Series Fuel Pressure Regulators have all of the great features as our 515/525 Series except for extreme capacity. Utilizing a massive ½” return orifice and -10AN ports, this regulators holds no bounds. With the bypass capability over 5 GPM at 5 PSI, this new regulator can handle blow through carbureted applications well over 1800 H.P., and for EFI applications using belt driven fuel pumps; even further (with a flattened regulation slope). Regulator comes in three different pressure ranges covering applications between 4 and 65 PSI.
FueLab Adjustable Fuel Pressure Regulators
FUELABAdjustable Fuel Pressure Regulators are designed with performance and flexibility in mind. They accept port style and non-port style union fittings without interference. These regulators are designed for EFI applications running between 25-90 psi BASE fuel pressure.
  • Precision pressure adjustment hardware
  • 1/8" NPT gauge port (for external pressure gauge, plug supplied)
  • 1/8" NPT pressure reference port with supplied barbed fitting
  • Option of -6AN return line port inline positioning for tight installs OR standard bottom return
  • All stainless steel hardware
  • Versatile bracket included
  • Long life fluorosilicone diaphragm
  • Fuel fittings sold separately
Prodigy Reduced Size EFI In-Line Fuel Pump
FUELAB has taken Fuel Delivery to the next level... Digital. Prodigy Fuel Pumps are the automotive aftermarket’s first and only speed controllable DC brushless driven fuel pump. Fuelab’s award-winning, patent pending designs offer improved durability, substantially higher efficiency, and lower current draw. With digital fuel delivery you get unheard of electro-mechanical efficiencies in a package half the size of competing pumps.
The 40401 pump flows 75 GPH @ 45 PSI and is rated up to 700HP. All the great features of our original Prodigy series in a smaller package! Get the benefits of a 255 lph rated fuel pump with less currrent draw and cross fuel compatibility all in a pure billet format.
Please contact us for unbeatable pricing on these products! Also keep in mind we will match or beat any competitors pricing on so called "package deals"
: Send us a PM|||||: DrewAtMAP|||||: 1-888-MAPERFORMANCE x 100|||||: dreget@MAPerformance.com
maperformance is offline   Reply With Quote
Old 07-05-2012, 04:20 PM   #2 (permalink)
PM for best pricing!!!
Old 07-06-2012, 04:18 PM   #3 (permalink)
Old 07-10-2012, 05:03 PM   #4 (permalink)
Old 07-12-2012, 04:52 PM   #5 (permalink)
Old 07-13-2012, 05:36 PM   #6 (permalink)
Old 07-16-2012, 05:15 PM   #7 (permalink)
Old 07-17-2012, 05:10 PM   #8 (permalink)
Old 07-18-2012, 03:49 PM   #9 (permalink)
Old 07-19-2012, 04:33 PM   #10 (permalink)
Old 07-20-2012, 05:26 PM   #11 (permalink)
Old 07-23-2012, 05:13 PM   #12 (permalink)
Old 07-24-2012, 05:01 PM   #13 (permalink)
Old 07-25-2012, 04:09 PM   #14 (permalink)
Old 07-26-2012, 05:05 PM   #15 (permalink)
