#1 (permalink) |
![]() Join Date: Nov 2006
Member Number: 48589
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ACT Heavy Duty Clutch Kits ACT's clutch kits for the SRT4 feature a Heavy Duty Pressure Plate that incorporates hardened diaphragm fingers for decreased wear and provides a generous 44% increase in clamp load over the stock unit with a moderate increase in pedal effort. Performance Street Disc(HDSS) Recommended for Street and Race, Quicker engagement, Quiet operation, Best organic friction material, improved hub and burst strength Spring Centered (4 Pad) Disc(HDG4) Recommended for Road Racing, Increased torque capacity and spline life, Good durability and spline life, Quiet operation, reduced driveline shock, Very harsh engagement, chatter Spring Centered (6 Pad) Disc(HDG6) Recommended for Road Racing and high power Street, Increased torque capacity and spline life, Very good durability and good spline life, Quiet operation, reduced driveline shock Solid Hub (4 Pad) Disc(HDR4) Recommended for Drag and Road Racing, Increased torque capacity, Fastest shifts, low inertia, Good durability but shortened spline life, Harsh engagement, chatter Solid Hub (6 Pad) Disc(HDR6) Increased torque capacity, Faster shifts, reduced inertia, Very good durability but shortened spline life, Absorbs more heat than 4 pad, Harsh engagement, some chatter ![]() ![]() Clutch Masters FX-Series Clutch Kits FX100: Street Performance The FX100 System uses the Power Plus I Pressure Plate with a custom heavy-duty Steel Back Organic friction disc. This clutch is engineered for heavy-duty street use. It is specifically designed for extended wear and additional clamping force for the enthusiast who has added an exhaust system, an intake system, up to 50hp NO2 upgrade, or other non-forced induction external bolt-ons. It features only slightly increased pedal pressure, longer life than stock, and normal clutch feel during engagement and disengagement for a very smooth operation. FX300: Street/Race The FX300 System uses the Power Plus I Pressure Plate with a Steel Back Segmented Kevlar disc. This clutch is designed for the ultimate street enthusiast or weekend racer running a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100hp NO2. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement. FX400: Race Performance The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4 or 6 wing (paddle) configuration, with the 4-wing being the more aggressive setup (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more streetable than solid or rigid designs. This disc is designed for long life, outstanding holding capacity, and rapid heat dissipation. Twin Plate Clutches Clutch Masters is proud to introduce the finest and most economical multi-plate clutch systems available for today’s high performance vehicles, the 725 and 850 Series. Clutch Masters Twin Disc systems are pure racing technology that also works well in high performance street applications. They are designed to hold tremendous horsepower and torque ratings, while retaining a very smooth operation. By slightly increasing the clamping force of the pressure plate and adding to the square inches of usable disc area, CM Twin Discs significantly increase clamping values with only a 25-50% increase in pedal pressure depending on the application. The cover assembly is machined from billet aluminum with 25% more tensile strength than the competition’s cast unit. The flywheel is machined from billet 6061-T6 aluminum to meet SFI spec 1.2 for competition in NHRA, NDRA, IDRC, IHRA, SCCA and NASA. Each aluminum flywheel includes a replaceable heat shield. Steel flywheels are also available on select applications. The 725 series is a smaller diameter assembly, which creates less rotating mass and offering quicker, and smoother shifting with much better throttle response. Available Stages
![]() Please contact us for unbeatable pricing on these products! Also keep in mind we will match or beat any competitors pricing on so called "package deals" : Send us a PM||||| : DrewAtMAP||||| : 1-888-MAPERFORMANCE x 100||||| : dreget@MAPerformance.com ||||| ||||| |||||![]() ![]()
Your source for SRT-4 performance parts!
1-888-MAPerformance dreget@maperformance.com AIM: Drewatmap Show off your ride here for weekly giveaways |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
SRTotM Moderator ![]() ![]() Join Date: Apr 2010
Member Number: 78946
Great clutches I'll call up there and talk with bill about getting me a TD
Huge thanks to Chris, Bill, And Bob @MAPerformane for 95% of all my parts
Huge Thanks to Kevin Warren For.. Many many things MAP EF4 stock block, stock head 452whp on EMS at 26 psi 100&92 octane mix Fully built long block and big numbers coming! |
#4 (permalink) |
Why does everyone want that clutch Chris when through 3 of then
And it's drew now Chris left map a while ago
#6 (permalink) |
Yeah ok lol
#7 (permalink) |
PM For pricing on ACT and Clutchmasters!!!
#8 (permalink) |
PM for best pricing!!!
#9 (permalink) |
#10 (permalink) |
![]() Join Date: Jan 2004
Member Number: 6648
I sent you a PM yesterday regarding an ACT DN4-HDSS. Just checking if you currenty have this kit in stock and, if so, how much? PM me please, thank you.
Mopar Stage 2.5 - 367hp/375tq
#11 (permalink) |
PM Sent!!!
#12 (permalink) |
#13 (permalink) |
#15 (permalink) |
No problem jdavis20. PM for best pricing!!!
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
