Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 2 > South/Southeast
Old 05-15-2007, 12:52 PM   #181 (permalink)
torque222's Avatar
Member Number: 11609
anyone in here going to memphis besides me and kevin (vschaos)? let us know, it's gonna be a blast......july 26,27,28 and comming home on the 29th...
agp 50 trim w/ hahn portfueler,mopar stage2 , lorenzo 60mm tb, perrin 3' turboback exhaust, jmb cai, aem uego wideband,mopar sts, prothane motor mount inserts, ptp hardpipe kit with greddy rs bov,cca fmic, ptp stage3 clutch w/ fidanza flywheel and bc stage2 cams.
torque222 is offline   Reply With Quote
Old 05-15-2007, 01:47 PM   #182 (permalink)
Buy/Sell section Moderator
dojaman666's Avatar
Member Number: 3804
Trader Rating: (33)
Quote: Originally Posted by vschaos
Hmm 2 1/2 hours aint bad. So $400 for a dyno tune? I know mine is decently tuned, but a dyno tune would prob be best? Being as I only get 16-17mpg...I need some better daily mpg Was that for a full tune with what you have and no time limit? What if you add something later will they retune for lil cheaper? I think my cams need to be adjusted....the $400 will include that?
I don't think the 400 includes the cams. Retuning later you will have to talk to them about that.
I just need to come visit you sometime this 7-10 seconds of cranking before it starts gets annoying. Soon I will turn on water/meth, put on next exhaust, and new hot pipe(if I get one), crank up boost, timing, ect
i had seven to 10 seconds of cranking when the idiot forgot to put my cam sensor mag in the cams.
Quote: Originally Posted by thepowertowin View Post
For a moderator, you're a dick and don't support the very forum that you work with.
All items for sale will use the proper format.
If you have any questions please see here:
http://www.srtforums.com/forums/f27/...elines-352468/
dojaman666 is offline   Reply With Quote
Old 05-15-2007, 02:34 PM   #183 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
Well mine was starting up fine both cold and warm...then he started overhauling things to get the tune right for wot and part throttle. He has now taken a job over in texas and couldnt finish the tune.....
Shop hours are 10am to 7pm Mon-Fri
Taking calls on Tuesdays and Thursdays
Old 05-16-2007, 12:24 PM   #184 (permalink)
guhfluh's Avatar
Member Number: 1745
MS doesn't use the cam sensor. It's probably yhe cold start cranking settings... mine still doesn't want to start cold, but that's because of the walbro255 not holding pressure. Once I start it and rev it for a sec it runs fine. If not it starts, then dies. It also has a long crank time because of the fuel pressure drop of and drain back when key off. It could be yoru problem. Walbro 255s are notorious for that.
guhfluh is offline   Reply With Quote
Old 05-16-2007, 12:27 PM   #185 (permalink)
guhfluh's Avatar
Member Number: 1745
What for?
Did you go to the lakefront meet a couple of weeks ago?
Old 05-16-2007, 12:55 PM   #186 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
What for?
Its the SRT nationals....I have been to them all. Last year it was a 16+ hour drive This year its only 5-6 hours worth of driving
Also I just put in the walbro pump a few months ago.... I will buy another...is there a better pump out there that I can upgrade to?
Old 05-16-2007, 04:47 PM   #187 (permalink)
guhfluh's Avatar
Member Number: 1745
I'd leave it until you verify that's the problem. You need a pressure gauge to monitor it.
Old 05-16-2007, 05:23 PM   #188 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
Well soon I am about to by a return line system....which means I see pressure, but also means my fuel table has to be completly redone
Old 05-16-2007, 07:40 PM   #189 (permalink)
guhfluh's Avatar
Member Number: 1745
Not if you keep the pressure the same...
Old 05-16-2007, 08:17 PM   #190 (permalink)
torque222's Avatar
What for?
not lately , i use to go to the lakefront every sunday across from joe's crab shack, but i have not been out to the lakefront since the storm....i guess i'll have to go out there soon.....
Old 05-16-2007, 08:23 PM   #191 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
thats true, but I have 750cc injectors that are rated at 750 at 43psi and the stock fuel pressure is 58psi...lol so thats alot of fuel. Another reason I think my pump may be going out...cause I have them in the 70% range in my fuel table and am running 11.8-12.0....
Old 05-18-2007, 10:31 AM   #192 (permalink)
dojaman666's Avatar
Member Number: 3804
Trader Rating: (33)
wow. I was using like 20% correction and had my af's around yours.
Old 05-21-2007, 07:29 AM   #193 (permalink)
guhfluh's Avatar
Member Number: 1745
You were pulling 20% from the MAP sensor on a DTEC. He is reading 70% VE on a Megasquirt. Alot different.
Unless Kevin was talking about 70% duty cycle.
Old 05-21-2007, 08:07 AM   #194 (permalink)
SRToc Member
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
Yes sorry I didnt clarify. I am reading 70% on the VE on the Megasquirt.
Old 05-21-2007, 11:21 AM   #195 (permalink)
guhfluh's Avatar
Member Number: 1745
No biggie. You can go up to 255% I think.
