#16 (permalink) |
![]() Join Date: Sep 2011
Member Number: 86347
Subscribed for results, Especially on the water injection
04 SRT-4: Under Construction
99 9-3: Daily Driver FS Thread: http://www.srtforums.com/forums/f416...5/#post9777568 |
| Sponsored Links | |||
Advertisement | |||
#19 (permalink) |
![]() Join Date: Sep 2010
Member Number: 81082
Well I don't get wrapped around numbers I just want see MBT and if water is helping or hurting. Also if I can improve my numbers and see if I can hot lap(back to back pulls) with out losing hp on water and e85. Ya know.
On meth and water I was able to dyno 3 times in a roll and only lose .2 hp.[/QUOTE] Trust me neither do I but I'd like to see where you're at. Mine was quite skewed. Very heat soaked, no fan on the dyno, 106 outside and roughly 140 in the shop. So I don't get hung up on the numbers much either. My track day hopefully doesn't get rained out again December 8th. But mine on water/meth I only made 372whp and 395 wtq then the next pull was done ten seconds after and I lost 10 whp an 10 wtq even though I have my ED super beast intercooler and water/meth
SRT: AGP .50 trim
Tuning on E85. Tuned by Mindmelt101 Last edited by ares559; 11-20-2012 at 05:21 PM. |
#20 (permalink) |
![]() Join Date: Dec 2010
Member Number: 82185
In for numbers, you think that DO4 is enough for the big turbo?
Just an idea but why not start the meth earlier so it is spraying fully when you're at full boost? I'm not sure how fast your turbo spools but I found with stock sized turbos if I started the spray at 15 the boost would spike and get a few counts of knock so it would pull timing before the meth had a chance to spray. My pump and tank is in the trunk though so maybe that has something to do with it.
280whp 303wtq 16g bws, injen short ram, meth injection.
Stock intercooler, manifolds, o2 housing, wastegate, and motor. Best et: 13.4 Best trap: 107 |
#21 (permalink) |
SRT of the Month ![]() Join Date: Aug 2005
Member Number: 32888
Not sure that's just it. Ill get with Darksyde to mail me a DO7.
I wish some one would chime in that smart with water injection.
#22 (permalink) |
![]() Join Date: Aug 2006
Member Number: 45182
You need to find your MBT and that should be your #1 priority on the Dyno. Your timing table is apparently working very well but despite your car's great performance, the WOT Timing is just a very well educated guess, thus it should have room for improvement.
1,2 and 3 on your list is not getting you anything you can't do on the street except you'll have a Hp number to go with it. Nice to talk about but not of any real value. If I were you I'd run the exact same boost you did on you 11.19 pass and do the following. 1) take a base line. 2) Add 2 degrees timing and make a pull 3) Closely compare the two dyno graphs to see where Tq was gained or loss 4) If improvement is made, add another 2 degrees or timing in that RPM range 5) If no improvement is made, remove 2 degrees of timing from the base timing value and make a pull. 6) Repeat steps 3-5 until Tq no longer increases. 7) Then Email me ALL the Dyno graphs, a detailed list of your timing changes for each pull and also your final timing changes. I'll analyze the results of you changes and make you a new tune.
1025cc Injectors+ E85/GAS Base tunes =$359ADD Boost By Gear to ANY PCM boost control tune $75 E85+Gas Base tune Combo $150*[*Only available for 1025cc Siemens/FIC1100&2150/AGP1200/All ID] PLEASE USE EMAIL!!dave at needlesstorque dot com Last edited by duster360; 11-23-2012 at 10:00 PM. |
#25 (permalink) |
![]() Join Date: Aug 2008
Member Number: 66615
Boo. Looks like I'm waiting until spring to install my coolingmist kit then. I'm attempting so set up a local dyno day in the spring. Maybe I'll run this experiment myself.
11.87@116.4 - stock turbo no N2O
http://youtu.be/yP6xoSjgWbA Last edited by DetroitSRT; 11-30-2012 at 10:59 AM. |
#26 (permalink) |
this will happen just on a different set up...
#27 (permalink) |
new turbo for spring?
http://youtu.be/yP6xoSjgWbA |
#29 (permalink) |
I thought you were keeping the 5831? Just adding a tubi?
#30 (permalink) |
![]() ![]() Join Date: Sep 2004
Member Number: 17477
Well that sucks man. Was looking forward to talking smack to ya.
DCR spiced and Tuned by the Mad Scientist team
![]() Jay@N2MB and Nigel@BST (turbo666) Mole' (STOCK TURBO) 16g BWS setup #s 380hp+ and 444tq+ 11.7@122 1.71 60ft PM/email me for all your 16g/18g/20g BWS setup and DCR needs...... Darrell Cox Racing on facebook, 1-517-369-9636 10am-5pm est webstore... DCRSRT.com. email me at mole79@aol.com . |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
