Ok everyone, Its been 2 weeks since I have had my car, Vione back. I have fixed all my other problems that i was having with it. Tranny cost $1600 to replace ALL synchros and 2,4 shift fork and a few other odd and ends parts. Also I need a good stock turbo if anyone has one availiable.
Sleeper, Give me a call. I got some info for you about Zeitronix. They just did a software update and it looks sweet!!!
---Lazy good for nothing tricksters, Crack smoking swinglers, Big butt having, wide nose breathing all the white man's air. They eat up all the chicken, they think they are the best dancers and they smell like collard greens!!!!---
I am in no way shape of form involved in any Nigg3rdom
well, i got my first testament to how the car is gonna run. matt changed out my stock t-stat to a 180 degree one. lowered the tires to 24 psi and decided to do a pull from a dig to see how the car was running. boost was set to about 10-12 psi and was creeping up to about 16 or so (the WGA isn't adjusted and the EBC is set really low, so there are some adjustments needing to be made, but the car only has like 7 miles on it since the build and nothing has been messed with lol) and this thing RIPS!!! the boost is set at 12 psi, but when it creeped up at like 4500 RPM's in third, it broke traction all the way to 6800 RPM's and part of 4th . even from a roll in 3rd, it still broke loose around 5000 RPM's or so. never pulled timing either. car drives really strong and solid on only 12 lbs of boost and a base flash tune. can't wait to crank this fucker up and see what it'll do. i think it is safe to say that tires won't last very long on the front lol. hopefully i have a teaser vid tomorrow of either an in-car pull or something.
Task Force H8'' Because when you are a hammer, the world looks like a nail''
It is on the level of sex, 45 roll on the interstate with a 03 cobra, and jumping out of a plane....flat out insane.
Go buy it right now and i sincerely meen that. I was walking across the street and a car hit me(yes you can get clipped by cars now), and then all of a sudden the driver gets out and want to throw down. Big mistake right? Nah, beat downs arent guarenteed anymore. The cussing is fucking insane!!! Buy ths shit now before it gets a re censorship like the last gta 3 had.
SARCASTIC.
FS: Complete turbo toys, O2 housings(stock/stage 3), stock IC, charge pipe, Stage 2 inj, Aeromotive FPR, plus other stock stuff...PM for offers
oh and keith, get with matt about the zeitronix. he told me all about it today on the phone.
Yeah we tested it tonight. You display works fine and also the unit itself is good. You know that you need a tach adapter to run the rpm signal. Exhaust depot has a how to on the matter.
Also get rid of that Stg2 wastegate. You know that thing is no good. Put the AGP on there
sounds like you are coming back on the same flight as me. if that's the case, you'll get to see the ride. it will be ready waiting for me at the airport when i get back. ill be drivin that bish 1st thing when i get on ground hehe
Cool bro,
i wish i could do the same but i don't trust my wife with my cars LOL.
i'll see you around bro. i'm interested on seeing that set-up of yours!
Quote: Originally Posted by card00d85
And what do you guys mean ziptie all vacuum lines? What do I ziptie them onto? I don't understand what you mean.
that isn't a stage 2 wastegate, its a stage 3 wastegate, and i have been on the list for ptp's new wastegate for the last month. it was supposed to release like 3 weeks ago, but john still hasn't gotten his shipment in, so im just waiting on that. read the instructions for the zeitronix, it accepts 0-12V square wave, tach signal or primary (low voltage) side of ignition coil. what that means is it doesn't need a tach adapter. if you have a tach adapter, then yes it will work with one, but you dont need one.
im all over it keith but thanks for the advice anyways.
stock cars are good but what is there to hide the sct
IF YOU GOT THE MONEY I WILL PLAY SOME BEAT THERE CAR TO HIT 11'S I DRIVE NORMAL
All DCR:motor,ProHead,oil system,intake mani,throttle body/spacer,Water injection,Battery kit,Greddy boost control,Crower stage 2 cams,fidenza cam gears
Turbonetics DBB 50trim, lots more GRANNY SHIFTING Best1/411.81 at 122.52 mph UNTUNED24psi Best1/8 7.69 at 94.38 mph UNTUNED22psi
hey granny shifter next friday will be my buddies first time at the track with his new setup 3076r u should come on down. or whoever else wants to come u are more than welcome to next friday at coastal .
http://groups.myspace.com/jacksonvillencsrt4s join if u are in jacksonville, nc area only
Best Trap - 1.79 60 FT 12.3090 at 114.53[/font]
ported stock turbo
