How much is the rebuild costing you. I need to get this done soon to.
it can cost you a little to alot pending on the way you go. I will build your motor for 500.00 bucks you buy the stuff i build it the way you want in 3 days or less.
suggest you go this way
dcr option A or B
dcr oil system
dcr tensionor
ether dcr,fullybuilt(josh),rage or a real tune head work
crower springs and retainers
crower cams stage 1 or 2
dcr lash ajusters if you dont go with there head
AGP turbo kit 50 trim or a 60-1 no 3076 they are junk on the srt
I built my own motor saved well over 2000.00 bucks buy doing it myself
My motor is strong untuned and hitting 11.8 at 122.52mph in the 1/4 with knock no higher then 1.5 you do the math
IF YOU GOT THE MONEY I WILL PLAY SOME BEAT THERE CAR TO HIT 11'S I DRIVE NORMAL
All DCR:motor,ProHead,oil system,intake mani,throttle body/spacer,Water injection,Battery kit,Greddy boost control,Crower stage 2 cams,fidenza cam gears
Turbonetics DBB 50trim, lots more GRANNY SHIFTING Best1/411.81 at 122.52 mph UNTUNED24psi Best1/8 7.69 at 94.38 mph UNTUNED22psi
dcr option A or B
dcr oil system
dcr tensionor
OK I got the footage,... will be posting the video on tuesday....but just to let yall know whats in it..........
Its Mr Stage II runing a 11.8 @ 122mph.................
...and an impressive 12.2 @ 124mph
One fast neon.
98 Camaro Z28:
Cam & Nitrous.....525rwhp/655rwtq
13.1@120mph..3rd gear spray, 2.4 60ft..
8.9 1/8th@90mph, Goodyear tires-non existing trac
almost car to wall encounters..6
dcr option A or B
dcr oil system
dcr tensionor
shane, i believe TSRT was talking about having his transmission rebuilt, not his engine lol. but as far as a street turbo goes, i would suggest the AGP Stage 3 Delta kit. 48 lb/min wheel, log manifold and external gating which is so much more advantageous over my big wheel stage 3 kit. i only wish AGP would have released this sooner. comes with injectors, fuel pump, and a preset flash tune. doesn't get much easier than that. AGP did this kit right. if you need more than what the Delta kit can offer, then you need to go ahead and step up to a built engine, EMS, 1000cc injectors and GT35R. Dave should be a good challenge for me..
AFTER he is tuned, of course
Task Force H8'' Because when you are a hammer, the world looks like a nail''
One fast neon.
tuesday what the hell i cant wait that long damn you
dcr option A or B
dcr oil system
dcr tensionor
Good job dude glad to see those slicks are working out for you..
dave, you need to sell whatever it is that you are using to tune with, and get a SCT flasher and have AGP make you some flashes for your PCM. no dyno tuning needed; all you do is do some passes down the track and datalog it, send it to AGP, and kevin does the rest. pretty straightforward, alot cheaper and easier, and 95% dead-on tune. the best part? it only takes like 3 min to flash to a different map and VASTLY improves driveability (near stock with ALOT more power). it controls everything; timing curve, fuel maps, ect. im tellin ya bro, you can't beat it. later on down the road, if you want to make your own tuning flashes, you can upgrade to the pro racer package directly from SCT and have access to all of that. alot cheaper than an EMS too. just my two pennies. doesn't look like HP Tuners will be coming out with any SRT-4 tuning software for awhile either.
dcr option A or B
dcr oil system
dcr tensionor
you're the man!
let's say i want to put either a mopar stage 3 or a agp stage 3 delta can you do that?
i'm looking foward to put that on my srt.
Quote: Originally Posted by card00d85
And what do you guys mean ziptie all vacuum lines? What do I ziptie them onto? I don't understand what you mean.
you're the man!
hey boss anything that you need that deals with the srt line being a 4 to 8 and even the the big dog i can do i have been dealing with the srt line on motors for a long time about almost 5 years let me know when and the price for install on turbo will be right around a 200 bucks witch is not shit the reason i say that price is because for someone else to do it will cost about 800 bucks.
GOT IT BRO!
I WILL HIT YOU UP! AS SOON AS I GET BACK!
TAKE CARE MAN!
