I dont believe AGP welds their flanges to the HOT side PIPE unless you ask for it that way.
IF you just order a agp hard pipes then the pipe with the flange goes to the right side of your intercooler.
Its easier if your remove your stock air box.
Remove the intercooler pipe along with the RED vac Line.
On the Hardpipe put the bov on with gasket or RTV... install hard pipe, plug in sensor, and Cap OFF where the red vac line goes to the solenoid.
now you need a boost source for the BOV TEE into the vac lines that go to your throttle body.
the hot side is the 90 (goes to left of the intercooler)
Thats my fifth grand education. dont mind the errors
04 Srt-4
"When the turbo spins the bullshit ends"
