Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 2 > Mid-Atlantic Area
Old 06-26-2008, 05:53 AM   #1 (permalink)
cocoadog's Avatar
Member Number: 9184
Default Lookin' to borrow a STUD PULLER
I am in need of a stud puller. I'm changin' all my studs to the stronger ones and I'd like to do it with a puller. I know I can just hammer them out but I've seen a lot of warnings about ruining your bearings etc. If I was just changing one I would consider that method. But with 20 total, I'd like to do it the "right" way. So...if ya have one ya'd let me borrow just drop me a line. I have checked all the local stores and non of them have them to borrow OR rent. Any help is appreciated. Thanks
cocoadog is offline   Reply With Quote
Old 06-26-2008, 07:10 AM   #2 (permalink)
SRTforums Veteran²
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (43)
what kinda stronger studs are yo using........the arp studs require a press to instell the studs......and last time i check they were the on ly better studs out there.........plus the back arp studs you have to drill the holes in the hub themselves out.....there too small of holes
sorry guys but the car is for sale....all out first gen is in the works
onthedwnlow is offline   Reply With Quote
Old 06-26-2008, 07:29 AM   #3 (permalink)
cocoadog's Avatar
Member Number: 9184
^^^You're kidding right? Man, I don't have that kind of mechanical experience. They are the ARP's and researching did not show that kind of install work. I mean, I did not know there was any drilling of hubs involved. I knew I had to work to get them in but that's a bit more then I wanted to encounter. Well anyone want to buy some studs? Just kidding.
Old 06-26-2008, 07:34 AM   #4 (permalink)
COY
COY's Avatar
Member Number: 35663
Trader Rating: (27)
Thats what I call your mom
Sorry, couldnt help myself.
Located in Kitsap County, I am the Northwest's premier sport, luxury, and import tuning facility.
Apparently that is all you have to do to make that claim.
COY is offline   Reply With Quote
Old 06-26-2008, 07:50 AM   #5 (permalink)
SRTforums Veteran²
Trader Rating: (43)
yeah arp studs are a pain in the ass....you will have to either take it apart and take them somewhere or take the car some where........the rear hubs have to be drilled out because they are smaller holes than needed
Old 06-27-2008, 10:24 AM   #6 (permalink)
Member Number: 64892
Performance Brake Parts, Rotors, Calipers, Discs & more! - RacingBrake.com they have some good studs... I am using them in my car
Paxman- destroying cars in the mid-atlantic
Fear gives way to reason and I fear nothing therefore I am not reasonable
2003 Dodge Srt-4 (Yes it's pretty modded)
1995 JDM Integra
1995 Talon 450whp
2003 GTI 1.8t
1995 Talon 16g turbo
2003 Mitsubishi Eclipse GT
Paxman is offline   Reply With Quote
Old 06-27-2008, 10:26 AM   #7 (permalink)
Also when installing them we put them in and used a impact gun and a lug nut on the stud partially pushed through to pull the studs through tightly and it worked fine for me
Old 06-27-2008, 10:43 AM   #8 (permalink)
cocoadog's Avatar
Member Number: 9184
Thanks, I did read that somewhere else. I also read to put them in the freezer before installation. But I still need a "safe" way to get them out.
Old 06-27-2008, 10:45 AM   #9 (permalink)
cocoadog's Avatar
Member Number: 9184
Well I'll see how that goes. I contacted RacingBrkes about the ARP's and asked them about the fit issue and they insist the studs are the same size as stock. If nec I may ONLY have to file out the hole a bit. We'll see.
Old 06-27-2008, 10:46 AM   #10 (permalink)
I actually just bought their extended length studs not the arp ones... good luck to you though man... yea I did wheels bearings at the same time so we just banged them out.. I don't know I'm sure you can fine some more info on here
Old 06-27-2008, 10:48 AM   #11 (permalink)
cocoadog's Avatar
Member Number: 9184
Still looking for the tool BTW.
Old 06-27-2008, 10:56 AM   #12 (permalink)
cocoadog's Avatar
Member Number: 9184
I just realized I bought the RacingBrake studs, NOT ARP's. So perhaps they will go in better than expected.
Old 06-28-2008, 10:05 AM   #13 (permalink)
Member Number: 58214
yea they worked fine for me man
megatoninduk2 is offline   Reply With Quote
Old 06-29-2008, 05:11 PM   #14 (permalink)
cocoadog's Avatar
Member Number: 9184
^^^ Did you have to enlarge your rear stud holes a bit?
Page generated in 0.31846 seconds with 11 queries
