Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 2 > Mid-Atlantic Area
Old 03-23-2007, 02:51 PM   #1 (permalink)
tonydsrt4's Avatar
Member Number: 40622
Trader Rating: (15)
Default dyno shows shocking results!!!
ok guys i went to the dyno to get some base numbers before i add any significant power mods well i came home with
hp 209 @ 5400 tq 238.0 @2300 wtf!!! mods are in my sig boost 15/14
Mods- I wouldnt worry about it...
12.45@ 108
tonydsrt4 is offline   Reply With Quote
Old 03-23-2007, 02:55 PM   #2 (permalink)
milkman102299's Avatar
Member Number: 25193
Trader Rating: (15)
I would say boost leak or pulled timeing
12.72@110 1.92 60' capitol raceway 205/50/17 faulken ziex tires 11-18--6 stock turbo
je 8.5-1 pistons .020 over-eagle H beam rods
agp standard 50 trim @23psi pump 28psi race
Greddy Profec B.-MSD DIS 2-SAFC II
PTP charge pipe
PTP 750cc-exhaust depot cold side pipe w/hks ssq
3inch intake-msd coil-stock CPU
side exit
Boomba Fuel Rail/AGP return line
Walbro 255-Dynotune 75 shot.
DCR powershift 2-balance shafts removed
milkman102299 is offline   Reply With Quote
Old 03-23-2007, 02:57 PM   #3 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (66)
what type of dyno?
Old 03-23-2007, 03:04 PM   #4 (permalink)
tonydsrt4's Avatar
Trader Rating: (15)
mustang dyno and i dont think i was pulling timing and check fors leaks found none. i reset the com and same results im getting a pic of the shet in a few
Old 03-23-2007, 03:10 PM   #5 (permalink)
gdflys's Avatar
Member Number: 78
Trader Rating: (26)
Mustang always read low IIRC
Greg Delp
gdflys is offline   Reply With Quote
Old 03-23-2007, 03:29 PM   #6 (permalink)
tonydsrt4's Avatar
Trader Rating: (15)
but that low stock they say 230 which we all know is false so...
Old 03-23-2007, 03:38 PM   #7 (permalink)
blue04intracy's Avatar
Member Number: 8243
mustang dynos are around 10-15% lower then other dynos
blue04intracy is offline   Reply With Quote
Old 03-23-2007, 03:47 PM   #8 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (66)
yep. mustang dyno is the culprit. They calculate differently.
Old 03-23-2007, 04:08 PM   #9 (permalink)
tonydsrt4's Avatar
Trader Rating: (15)
so maybe it is the dyno not my car??? i know the guy who has the dyno and told me that he got some new soft ware and that they came out and calibrated it the week before
Old 03-23-2007, 04:08 PM   #10 (permalink)
tonydsrt4's Avatar
Trader Rating: (15)
Old 03-23-2007, 04:08 PM   #11 (permalink)
tonydsrt4's Avatar
Trader Rating: (15)
Old 03-23-2007, 04:19 PM   #12 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
If you've already checked for boost leaks and have none then you are right on pretty much with a Mustang dyno vs a Dynojet. You'd be right around 230 hp everybody is getting on a Dynojet. Without the mapclamp you are probably pulling some timing boosting that high on stage 0. No reason to be disappointed. How's your A/F boosting that high on stage 0? Did you do A/F when you dynoed?
'05 Stone White SRT 4
Mods - Yes
Web Page
http://qt.ptenthusiasts.net/
White Heat is online now   Reply With Quote
Old 03-23-2007, 04:34 PM   #13 (permalink)
tonydsrt4's Avatar
Trader Rating: (15)
yes we did im trying to fix my scanner to get the paper up on here so you guys can take a look on the chart i have it is between 10.3/11.8
Page generated in 0.18526 seconds with 13 queries
