Quote: Originally Posted by orange_blaster
Dont know if id even call it a kill, but yeah, no HOM, otherwise I think he would have been toast. Gas sucks. 92 is best I can get. If I go up to lakenheath I have to buy octane booster because the base gas sucks even worse. They label it as 97 around town, but you have to subtract like 5 octan because they formulate it different over here.
They give the RON there.
Racing fuels are usually classified the same, but list the RON, and MON.
Here, you get the average of the two.
What is 97 there, R+M/2 is 92, and actual MON is 87. Probably typical of 92 octane here.
That's why 100 octane, R+M/2 here, can be as low as 93 or 94 MON.
VP Racing fuels MS109 unleaded is 109 RON, 101 MON, with a 105 R+M method. It's realistically, 101 octane gas.
Leaded C16 is actually 116 MON. Basically, you can hold a lighter under it, and have trouble setting it off! (Okay, not really, but you get the point!)
RON is the "actual" octane. MON is the octane, under a pre-determined load, in a single cylinder engine, etc......
This is why different octane gasolines, actually don't follow the same stoich pattern for complete burn. 14.7 is used because that's very close for most gasoline sold in the USA that doesn't come out of a racing barrel, and most gas companies strive to ensure that their gasoline burns completely at that point.
You find recommendations on race fuel sites, for running certain blends in the 13.5 range, and other blends closer to 11.5..... This is because they burn differently.
Higher MON #'s, on the same R+M/2 will perform better in real applications. And, the higher the MON, because actual loads are much more extreme than the pre-determined figure used generally, is an indication of how it will do, but slight increases in MON can actually be much larger in anti-knock qualities, in reality.
