Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Form and Function Performance
Old 06-09-2008, 10:53 AM   #106 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Ok, so the results are finally in! After 3hrs of portwork per kit (x2 kits) and ~11hrs of manifold swapping and dynoing, with a few breaks in between (oh yes even the hail-not kidding- wouldn’t stop us) we have our information.
Once again I would like to thank AGP turbo for donating the manifolds and turbine housings to this test, MA Performance who not only was gracious enough to donate the dyno time, but also their patience to stay late and let us finish the testing after we went past our original estimate by 3-4+hrs, and to the Form and Function Performance team for the hard work in the porting, coating, and installation of these kits. Thank you also to Dan for supplying the test car for this as well.
The scope and purpose of this test was to show the effects of porting and ceramic coatings on AGP’s manifolds and Garrett turbine housings. What was tested was an older cast AGP manifold and Garrett turbine housing (Dan’s existing setup), a new cast AGP manifold and a new Garrett turbine housing as a control test to ensure design differences and any carbon buildup are not present to skew testing, a ported cast AGP manifold and ported Garrett turbine housing, and finally a ported and coated cast AGP manifold and a ported and coated Garrett turbine housing. All Garrett turbine housings were T3/T4 (50trim) housings with .63 a/r’s. The same CHRA and compressor cover were used in all tests.
This test took place at Modern Automotive Performance (MAP) located in Plymouth, MN on their Dynojet Dynamometer. It was a great facility that had plenty of room for us to perform our tests and swaps, without affecting their regular flow of business.
Test car info:
04’ Dodge Neon SRT-4 (42,xxx)
~4gal 110 leaded gas with ~2-3gal of 92 mixed in
Mods:
AGP Turbo kit, 50 trim, .63 a/r, older style cast log manifold
Mopar Stage1 PCM
FIC 750cc injectors
Walbro 255lph fuel pump
AGP’s return line kit, RRFPR set to 37psi (vacuum line on)
Ultimate racing FMIC
Ultimate racing cold side hard pipe w/ HKS SSQ BOV
Needswings 3” down pipe w/ cutout (cutout closed for testing)
MPX 3” catback exhaust (no cat)
EVC-6 Electronic boost controller set to 25psi
Apexi Neo fuel controller
Stock head, stock cams, stock intake manifold, stock TB
Test was run without any CAI on the turbo for the ease of installation of the kits.
Along with the dyno information, we used a Zeitronix ZT-2 data logging system to obtain, RPM, EGT’s (probe failed partway through testing), boost, throttle position and AFR’s. We also used two thermocouples to test temps at the base of the turbine housing (outside the manifold) and ~2in away from the manifold (in between the WG and turbine housing).
Testing procedure was to bring the test car up to temp (185 degrees Fahrenheit) before conducting three back to back dyno runs coming to a complete stop in between runs. Average time in between pulls was ~30 seconds. One large fan was used to cool the front of the car down although we still saw signs of heat soak on the motor. NO SETTINGS WERE CHANG4ED IN BETWEEN RUNS OR TESTS. The boost level remained the same, the fuel pressure remained the same, and no change on the tune.
First step was to get Dan’s car into a bit better tune (was running WAY rich) so the first 1 ˝ hrs were spent getting his car tuned better and diagnosing a few vacuum lines that blew off. Once that was done, we had a starting point and did the ‘as is’ test.
Test 1: ‘As-is’ (existing setup on car) (older style AGP cast manifold)
Results showed that the first pull was the ‘best’ in terms of power and each of the next two pulls were slightly less due to heat soak. Dyno sheet shows all three runs in this test.
Data Log Test 1 Run 1
Data Log Test 1 Run 2
Data Log Test 1 Run 3
Temp readings for surface were 330/432/506 and 220/2230/237 at 2” ambient.
Overall results: baseline for consecutive tests
Form and Function Performance, LLC
Trust those who KNOW performance, not just sell it
Your turbo upgrade/rebuild, airflow, and thermal management specialists!
|612-385-0419| |www.FFPerformance.com| |sales@FFPerformance.com|
a853rox is offline   Reply With Quote
Old 06-09-2008, 10:54 AM   #107 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Test 2: New cast AGP manifold and New Garrett turbine housing
Results showed that the second pull was the ‘best’ in terms of power. We did have issues with the EGT probe and did a 4th pull to log egt’s after rerouting the wiring for the sensor (very sensitive to EMI).
Dyno graph shows all runs for this test
Data Log Test 2 Run 1
Data Log Test 2 Run 2
Data Log Test 2 Run 3
Data Log Test 2 Run 4-EGT
Temp readings for surface were 205/245/292 and 160/190/245 at 2” ambient.
Overall results: baseline for consecutive tests, control for first test
Old 06-09-2008, 10:54 AM   #108 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Test 3: New cast AGP manifold (ported) and New Garrett turbine housing (ported)
Results showed that the First pull was the ‘best’ in terms of power with the consecutive runs showing heat soak again. The EGT probe’s tip actually broke off during the first run of this test but thankfully there was no turbine damage done.
Dyno sheet shows all runs for this test
Data Log Test 3 Run 1
Data Log Test 3 Run 2
Data Log Test 3 Run 3
Temp readings for surface were NA/360/365 and NA/190/220 at 2” ambient.
Overall results: showed improvements (quicker) in spool by ~75rpms, and with the exception of one small blip at ~3600rpm showed improvements in torque across the entire rpm range up to 36ftlbs more (average of ~15tq more in the midrange and ~7wtq above 5500) and power across the entire rpm range up to 25whp more (average of ~11hp more all the way to 6,000rpm) when compared to the baseline run.
Manifold to turbine transition after portwork:
Old 06-09-2008, 10:54 AM   #109 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Test 4: New cast AGP manifold (ported and ceramic coated) and New Garrett turbine housing (ported and ceramic coated))
Results showed that the First pull was the ‘best’ in terms of power with the consecutive runs showing heat soak yet again.
Dyno sheet of all runs for this test
Data Log Test 4 Run 1
Data Log Test 4 Run 2
Data Log Test 4 Run 3
Temp readings for surface were 590/682/778 and 245/225/295 at 2” ambient.
Overall results: Interesting temp results from the ceramics. You can clearly see how although the ambient temps are in line with the other tests, the surface temps illustrate that indeed the ceramics do reflect thermally as shown by drastic increase in surface temps. From there we showed improvements (quicker) in spool by ~100rpms, and with the exception of small blips at ~3400 and 3600rpm showed improvements in torque across the rpm range up to 51ftlbs more (average of ~20tq more in the midrange but lost up to 10tq above 5700rpm ) and power across the rpm range up to 36whp more (average of ~15hp more all the way to 5,700rpm losing ~8hp above 5,700rpm) when compared to the baseline run.
Old 06-09-2008, 10:54 AM   #110 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Also when comparing to test 2 vs. test 3 you can clearly see that there are improvements from the coating alone. The testing shows an additional improvements in spool, ~8tq more up to 5,700rpm then a slight dip, ~5hp more up to 5,700rpm then a slight dip.
Dyno sheet ported(blue) vs ported and coated(red)
In conclusion it is clear that there is merit to porting these kits for improved power and slightly better spool. It is also evident that the ceramic coatings also have merit as well. While I would like to say that EGT’s were also reduced, the EGT probe failure has prevented us from proving this. Also keep in mind that AGP has a great product but just like any other cast manifold or head, there will always be room for some improvement.
Dyno sheet comparing unmodified(blue), ported(red), and ported and coated(green)
Pic of test pieces:
Broken EGT probe :
Car is wired for sound!:
Ported and coated turbine almost installed:
Turbine housing ported:
Turbine housing ported and coated:
Old 06-09-2008, 11:09 AM   #111 (permalink)
Pit Viper's Avatar
Member Number: 339
Trader Rating: (67)
Unreserved 6
Good-bye, SRT.
Old 06-09-2008, 11:25 AM   #112 (permalink)
Nelson's Avatar
Member Number: 52787
Bingo!!!!
Removed due to Communists
Stage Slow.... Back to stock
Nelson is offline   Reply With Quote
Old 06-09-2008, 02:22 PM   #113 (permalink)
redhotneon's Avatar
Member Number: 18438
Trader Rating: (20)
any idea when official results will be posted so im not checking back every hour?
redhotneon is offline   Reply With Quote
Old 06-09-2008, 02:44 PM   #114 (permalink)
Pizza Boy's Avatar
Member Number: 49788
Trader Rating: (64)
Currently Active Users Viewing This Thread: 3 (3 members and 0 guests)
Pizza Boy, a853rox, Venomm
were waiting....
Quote: Originally Posted by JPG View Post
My boyfriend wanted a hand-job but i couldn't get a good grip because he had a chode.
Pizza Boy is offline   Reply With Quote
Old 06-09-2008, 03:16 PM   #115 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
were waiting....
Well take a look at posts 106-110 foolio!!
Waiting is over!!!!!!!!!
Old 06-09-2008, 03:31 PM   #116 (permalink)
Pizza Boy's Avatar
Trader Rating: (64)
Nice , numbers...all those numbers seem totally realistic as well, Im impressed...you gaind 5ft/lbs with just the coating..
Old 06-09-2008, 03:34 PM   #117 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Thanks!
This is the first time that I have had the chance to validate the manufacturer's claims, but the coatings do work!
(they claim 2-6% in turbo applications so at 400whp it should be ~8-24whp)
Old 06-09-2008, 03:57 PM   #118 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Currently Active Users Viewing This Thread: 8 (7 members and 1 guests) a853rox, brianbr, duster360, Moving Darkness, OTownSRT4, redhotneon, wonderboy
Old 06-09-2008, 04:09 PM   #119 (permalink)
Monster's Avatar
Member Number: 48761
Trader Rating: (68)
Impressive power gains
www.pt-performance.com
Tunes send your request to tunes@pt-performance.com
Old 06-09-2008, 04:09 PM   #120 (permalink)
Jagok1's Avatar
Member Number: 14366
Trader Rating: (18)
Not bad, not bad
AGP GT40 -> 317@16psi -> 370@21psi -> Race #'s soon Tuned by NemoFoss
Jagok1 is offline   Reply With Quote
Page generated in 0.32638 seconds with 14 queries
