#1 (permalink) |
![]() Join Date: Mar 2012
Member Number: 88575
Went from a 25 he missed 3rd but here's the vid
https://www.youtube.com/watch?v=Rphk...e_gdata_player
12.4@110 23" slicks 1/8 60'
13.1@109 street tires 2.1 60' Not bad for a car that gets 35mpg |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
SRTotM Moderator ![]() ![]() Join Date: Apr 2010
Member Number: 78946
HX40??... lol damn that thing got spanked while he had a retorted look on his face the entire time...
but i would like to see it when he doesn't miss 3rd
Huge thanks to Chris, Bill, And Bob @MAPerformane for 95% of all my parts
Huge Thanks to Kevin Warren For.. Many many things MAP EF4 stock block, stock head 452whp on EMS at 26 psi 100&92 octane mix Fully built long block and big numbers coming! |
#4 (permalink) |
The camera died on the 2nd race he got it in third From 35-100 I had like a car after 100 he got like one two car pull
#6 (permalink) |
Member Number: 90881
https://www.youtube.com/watch?v=Rphk...e_gdata_player Wait. Your car gets 37mpg?? If so share some secrets. Mine only gets 25.
#7 (permalink) |
![]() Join Date: May 2008
Member Number: 63759
What are you talking about? Also, why even bother posting an incomplete race...for the record, that turbo on a properly setup car would completely trash a stock turbo neon.
Stone White 05 - Built Motor, Built Head, e85 & 75lbs/min - coming soon
#10 (permalink) |
Member Number: 91562
Well that was sorta a useless video
![]() What's the deal with these HX40's. Any Holset guys on here? A HX40 seems to be a 60mm turbo with a huge 76mm turbine and a t4 housing? Correct? I guess they are turbos designed for large displacement diesels. That'd explain the large turbine and a small compressor. On a small motor like the golf such a large turbine wheel/housing will result in slow spool. It just seems to me that it's a mismatched turbo for small engines? |
#11 (permalink) |
![]() Join Date: Dec 2010
Member Number: 82263
Also, why even bother posting an incomplete race...for the record, that turbo on a properly setup car would completely trash a stock turbo neon. I agree with this 101%
Tuned by Brian (Mindmelt101)
#12 (permalink) |
![]() What's the deal with these HX40's. Any Holset guys on here? A HX40 seems to be a 60mm turbo with a huge 76mm turbine and a t4 housing? Correct? I guess they are turbos designed for large displacement diesels. That'd explain the large turbine and a small compressor. On a small motor like the golf such a large turbine wheel/housing will result in slow spool. It just seems to me that it's a mismatched turbo for small engines? A turbo is a turbo. In this case, the HX40 is on par in terms of size and power potential with the Borg Warner S360 series. The compressors range from 60lbs/min to 69lbs/min stock, there is a billet version of the 69lbs/min wheel and a batmowheel made by Bullseye Power that has clocked over 70lbs/min. It's just a big ass turbo capable of 600 ~ 750whp pending your setup. For the most part you are right, it's a bit large for that Golfs motor, unless it was built for larger turbos/meant to flow and actually put such a big turbo to use but not many people think that far ahead and slap the biggest fucking turbo they can get into a car to say 'hurrrrrrr i gots teh big sausage1'. They are cheap too. To diesel trucks/Cummins guys they are tiny useless turbos, but to gasoline powered cars they are mid sized to larger. They are cheap, I bought my HX35 (s256 sized) for $150, it's the 7 blade compressor which flows 60lbs/min. The hotside on it is comparable scale is 0.89ar, stock 12cm divided T3. It might be a bit large but it's perfect for this top end turbo. I see 20psi by 3.4 ~ 3.6k RPM. Bullseye Power makes various T3 and Mitsu flanged hotsides for the Holset series, so you can get varying sized hotsides if you'd like (yes the stock ones are HUGE on the HX40). One more note, just because they are cheap doesn't mean they don't last. They were built to be beat to shit, over boosted and over heated - most diesels are running these at 40+psi all day. In the car world most will be in the high 20s and the guys going for serious power can probably afford to replace something if it breaks lol. Hope that helps.
#13 (permalink) |
For the most part you are right, it's a bit large for that Golfs motor, unless it was built for larger turbos/meant to flow and actually put such a big turbo to use but not many people think that far ahead and slap the biggest fucking turbo they can get into a car to say 'hurrrrrrr i gots teh big sausage1'. They are cheap too. To diesel trucks/Cummins guys they are tiny useless turbos, but to gasoline powered cars they are mid sized to larger. They are cheap, I bought my HX35 (s256 sized) for $150, it's the 7 blade compressor which flows 60lbs/min. The hotside on it is comparable scale is 0.89ar, stock 12cm divided T3. It might be a bit large but it's perfect for this top end turbo. I see 20psi by 3.4 ~ 3.6k RPM. Bullseye Power makes various T3 and Mitsu flanged hotsides for the Holset series, so you can get varying sized hotsides if you'd like (yes the stock ones are HUGE on the HX40). One more note, just because they are cheap doesn't mean they don't last. They were built to be beat to shit, over boosted and over heated - most diesels are running these at 40+psi all day. In the car world most will be in the high 20s and the guys going for serious power can probably afford to replace something if it breaks lol. Hope that helps. Thanks, I appreciate the information. There's a couple people around my town who've got HX40's on and I could never find much information on them. A shop a few garages down from ours works on volvos and he had my buddy do some exhaust work to make an HX40 fit in their track car. It's a fully prepped road race volvo and switched the HX35 out for a HX40. Said he pulled it off a city bus lol! I've got a GTX3582R with a tial 1.06 housing. It's a 62.5mm compressor with a 68mm turbine. The Hx40 made mine look small lol. It looked like a 40r, which minus a 65 mm compressor I guess it is? Last edited by Vaderwrx; 01-02-2013 at 08:42 PM. |
#14 (permalink) |
I come from the dsm world you can get a turbine housing as small as .62 for a holset. The one on this car is a t3 with. And the car did trash me once it got in gear after the camera died. The motor is fully built in the golf.
#15 (permalink) |
dont hit boost. I get 30 on base all day if i drive like a grandpa. And my best mpg is actually 36. I spent $15 to drive 120 miles and thats with hitting some boost around the turns in the mountains
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
