Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > SRT Videos
Old 10-17-2009, 11:30 AM   #1 (permalink)
chrishna's Avatar
Member Number: 47605
Default srt4 vs evo9/evox/tc cobalt/ tc civic/ ms3....
all stock turbo cars
YouTube - Evo X vs. Civic and SRT4
YouTube - SRT4 vs Evo X vs Turbo civic Race 1
50 roll
YouTube - Evo IX vs SRT4 vs Turbo Civic race 3
40 roll
YouTube - SRT4 vs Evo IX vs Turbo Civic Race 2
20 roll
YouTube - Cobalt SS Turbo Sedan vs Turbo Civic vs SRT4
YouTube - Cobalt SS Turbo Sedan vs SRT4 vs MS3
@ 1;24 in me vs camero vs turbo civic on low boost vs srt4
YouTube - Daytime Runs
@ 6;24 in me vs intake/pully/headers 6.0 gto
YouTube - pullin at hmp!
@1;32 in me vs mazdaspeed3 from a dig. vs turbo civic vs evo 9 mr
YouTube - SSF: SC61 Evo vs 35R STI | LS3 Corvette vs Cobra, Camaro | Srt4 , Turbo Civic , turbo Cobalt Sedan
YouTube - 300hp srt4 vs stock 6.0 gto
YouTube - 300hp srt4 vs stock 6.0 gto 2
YouTube - nsrt vs csrt4 vs turbo cobalt vs mustang cobra
399hp. 423tq stock turbo with 60 shot
chrishna is offline   Reply With Quote
Old 10-17-2009, 02:46 PM   #2 (permalink)
sideck's Avatar
Member Number: 9705
Trader Rating: (29)
nice runs bro...
SIDECK - RRT
sideck is offline   Reply With Quote
Old 10-17-2009, 03:24 PM   #3 (permalink)
SRTrent's Avatar
Member Number: 65861
chrishna what are your mods?
SRTrent is offline   Reply With Quote
Old 10-17-2009, 09:54 PM   #4 (permalink)
chrishna's Avatar
Quote: Originally Posted by sideck View Post
nice runs bro...
thanks
3''dp/bfmic/dsp 93t/water-meth/s2 injectors/55mm tb. spiking 20-22 holding 14-15psi.
on the last vid with the csrt/cobalt ss and mustang that was without the meth.
Old 10-18-2009, 12:03 AM   #5 (permalink)
SRTrent's Avatar
how much do you boost without the water/meth? how much is safe? i got a little extra power out of my DSP but I want more and my boost seems to wanna adjust itself. Is the boost on the scangauge more accurate than the stock boost gauge? I just now was showing up to like 19.x boost on the scangauge and I'm on stock fuel system
Old 10-18-2009, 12:28 AM   #6 (permalink)
Member Number: 33203
Trader Rating: (25)
The boost on the scan gauge reads off the map sensor, so assuming you aren't running a piggyback that is clamping the voltage, then it should read very accurately. Seeing that you're on dsp, I would assume you don't have a piggyback. If your boost gauge is still reading from the factory line to the brake booster, you could be losing a few psi between there and the intake manifold ( where the scan gauge reads at), plus autometer boost gauges tend to be a few psi off anyway.
I use a digital vei systems boost gauge, which should be more accurate, but I still tapped a fitting into my throttle body spacer and ran the boost gauge line from there so that it would be more precise as to what was actually going in the motor.
Precision 6057@30psi on pump
8.50@87 on 10psi w/2.0 60 ft (wg pressure on 30 psi tune, no 2 step)
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is online now   Reply With Quote
Old 10-18-2009, 01:40 AM   #7 (permalink)
Srtkr's Avatar
Member Number: 66584
i laughed so hard at the air horn hahahahahaha but seriously good videos
Srtkr is offline   Reply With Quote
Old 10-18-2009, 09:22 AM   #8 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
the vei gauge is definately not accurate. i just took mine out. it was 3 psi off from my scan gauge
View Modifications
Old 10-18-2009, 09:43 AM   #9 (permalink)
Trader Rating: (25)
Read what I posted.
I bet if you hook it up to where mine is hooked up, it will be almost dead with the scan gauge. Mine is That is assuming you don't have a leak between the tbody spacer and the intake manifold.
Old 10-18-2009, 12:55 PM   #10 (permalink)
SRTrent's Avatar
Thanks turbojon. What's the limit of the stock fuel system? 18psi?
Old 10-18-2009, 01:59 PM   #11 (permalink)
Member Number: 7855
did the SS have any mods?
05 SRT4: PTP Check Valve, DCR oil modifier, 160-tstat, K&N, Alky Injection, needswings 3" dump, Fm WGA and Stage 2
OH AND:
1993 Corolla DX 1.8L
1970 Buick Skyark GS
04COMPG is offline   Reply With Quote
Old 10-18-2009, 03:53 PM   #12 (permalink)
richardosrt's Avatar
Member Number: 73584
yeahh!!!
nice vid´s
richardosrt is offline   Reply With Quote
Old 10-18-2009, 04:07 PM   #13 (permalink)
chrishna's Avatar
i run the same boost with or without meth, without meth i run 11.5 a/f ratio. with meth 12.3-5a/f ratio + 35degrees timing @ 6k rpm.
before the s2 injectors and meth i was spiking 19-20pis falling to 14-15 @6k rpm. a/f ratio was 11.8-12.0 stock fuel system+ fuel pump rewire from ptp
280hp 330tq
according to my boost guage am holding 18-19 psi @6k rpm but the dsp is showing 14-15 psi hold @6k rpm
thanks bro
are you talking the cobalt ss or the camaro ss
cobalt in the 1st couple vid; tune and k/n drop in filter(they hold 22psi to redline)
in the last vid, same cobalt plus exhaust.
camaro ss; miner bolt ons
Old 10-18-2009, 09:03 PM   #14 (permalink)
Trader Rating: (25)
Yeah I'd guess 18 psi is about all that's safe without any fuel mods.
Old 10-18-2009, 09:39 PM   #15 (permalink)
SRTrent's Avatar
Son of a bitch. I don't really wanna max out the stock turbo but I do want more out of it though A lot of people think I won't break into the 12's with slicks/bolt on's/tune so I wanna prove them wrong =)
Page generated in 0.15736 seconds with 13 queries
