Sorta crappy video of 28 lbs of boost. - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > SRT Videos
Old 11-17-2012, 03:38 PM   #1 (permalink)
_Nick_'s Avatar
Member Number: 8941
Default Sorta crappy video of 28 lbs of boost.
I was getting the car ready for track day and datalogging as well as seeing how the car ran on 28psi for the first time. Ran excellent. Unfortunetly at the track it was slower, due to a number of factors. Heres one of my videos anyways. Watch in 1080p, because the GoPro doesn't do well in dark settings.
28psi on E85 - YouTube
20G Stage 3 on E85: New data:384 hp 411 tq
"Maybe I should just stick to bolt-ons." -Hitler
I don't really want to wrench anymore. I'd rather detail.
_Nick_ is offline   Reply With Quote
Old 11-17-2012, 04:07 PM   #2 (permalink)
rebellionyst's Avatar
Member Number: 59345
Nice. What BOV is that?
D55 POWERED
Quote: Originally Posted by contraption22 View Post
You know what would be the perfect thing for a Hella Flush meet at the beach?
A Tsunami.
rebellionyst is offline   Reply With Quote
Old 11-18-2012, 05:33 AM   #3 (permalink)
_Nick_'s Avatar
Member Number: 8941
The blue Mopar plate.
Old 11-18-2012, 06:24 AM   #4 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Nice Nick.
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 11-18-2012, 10:30 AM   #5 (permalink)
_Nick_'s Avatar
Member Number: 8941
Thanks Dan.
I am gonna work on some things for the track. The car's WAY faster on the street that it is on the track. I think the IC is a big reason why, it was also over 100 @ the track.
Old 11-18-2012, 04:47 PM   #6 (permalink)
csufdrew's Avatar
Member Number: 1843
E85 and your water injection should have helped.
113mph is weak considering Zenkat went 128mph in the same conditions. I'm sure your BWS3 moves out but 113 is embarrassing. Have you been to another dyno other than the one you put down 460 on? Cause clearly that reads high....with did other members put down on that dyno? Those certainly aren't comparable to dynojet readings.
Stage 3 turbo / E85 / SCT PRP
12.133 @ 120.490 MPH
csufdrew is online now   Reply With Quote
Old 11-19-2012, 07:33 AM   #7 (permalink)
_Nick_'s Avatar
Member Number: 8941
joedoogan put down 305 on that dyno on E85.
My slicks were rubbing the spring perches HARD. I think they significanty slowed me down.
I agree its embarrassing. Its why my sig is so small.
Old 11-19-2012, 09:26 AM   #8 (permalink)
csufdrew's Avatar
Member Number: 1843
Lol after watching the video, something is definitely going on in the back half....sounds like its breaking up and stumbling up top...
Old 11-19-2012, 10:02 AM   #9 (permalink)
Rhunter's Avatar
Member Number: 36794
Nick,
I know you have put a ton of work getting your car back together and running. Did you check the basics? Coil, wires, plugs? How about plug gap?
If you are running higher boost, you need to gap them down. My track plugs are gapped between .025 - .028
This next bit will not be very popular with the majority of SRT-4 owners, but IMHO as you go up in boost, a colder plug should be ran. I personally love 4306's but my car does not!! You might hafta find a colder plug my friend.
Nunca Levanta!
EL RALFO RACING.COM
"A Lotta turbo, Small motor, and a GO pedal!!!"
Old 11-19-2012, 10:48 AM   #10 (permalink)
Millernz123's Avatar
Member Number: 60887
Quote: Originally Posted by Rhunter View Post
Nick,
I agree with this 100%, close the gap and try colder step plugs.
http://www.indianasrt.com/
Built motor by Kriegspeed
Millernz123 is offline   Reply With Quote
Old 11-19-2012, 11:32 AM   #11 (permalink)
_Nick_'s Avatar
Member Number: 8941
NGK 4306's gapped at .028
The problem in the back half is 4th gear: When I let off the gas and clutch I lose boost and go back to vacuum (no suprise there) and then put the transmission into 4th gear. When I let of the clutch and hit the gas, the duration of time it takes to respool is tremendous. WHY? IDK. It's literally like half a second.
Once I begin boosting I sppol fairly quick, but in the "threshold barrier" between vac and boost there is a long time.
This is with the 3" downpipe open BTW.
Old 11-19-2012, 12:45 PM   #12 (permalink)
Zenkat's Avatar
Member Number: 10522
Is the gauge accurate? It looked more like a short spike to 28 but only holding 25 for most of the range, then down to 22-23 at the end.
11.21@127.88
Zenkat is offline   Reply With Quote
Old 11-19-2012, 02:30 PM   #13 (permalink)
Member Number: 80149
That gauge is all kinda of crazy! None the less, car looks like its moving out...
PTE 5858sp @ 24psi - Supporting Fuel - Stock internals
Contact Duster360 and Turbo666 for Diablosport tuning.
Quote: Originally Posted by thunt View Post
Ooooooh I get what your saying, because you don't drive it everyday means a:f's in the 16s are safe. My mistake...
jershelb is offline   Reply With Quote
Old 11-19-2012, 06:19 PM   #14 (permalink)
jay05acr's Avatar
Member Number: 37744
Needs more fmic....
Good job on the car broski, a little more tinkering with shit and I'm sure it will run like a raped ape
Go to wikyd-performance.com for all of your srt4 performance needs. Contact jtm0n3y or wonderer86 for more info
http://www.srtforums.com/forums/f416...-parts-639326/ my for sale thread
jay05acr is offline   Reply With Quote
Old 11-20-2012, 04:33 AM   #15 (permalink)
Rhunter's Avatar
Quote: Originally Posted by jay05acr View Post
Needs more fmic....
IDK man,
A local that I go to the track with traps 120whp with a stock wheeled stage 3and the stock inter-cooler. This is a full weight car with baby seat!
Nunca Levanta!
EL RALFO RACING.COM
