| Sponsored Links | |||
Advertisement | |||
#62 (permalink) |
![]() Join Date: May 2007
Member Number: 53956
Chief, you're exactly right. I knew it, we all knew it.
What I'd like to point out is this: Instead of claiming that his SRT held X psi to redline, arguing about it, then getting mad and leaving, LIKE 99.99% NOOBS, he stuck around, and did a datlog for the results. He trusted the boost gauge. Error? Sure, but bad practice? Not always. I give him props for the datalog Props King With his Meth spraying again the AFR's will be back to their previous lower state. Thanks nick for the log now that i got the meth working right we'll do it again.. well iv already posted two videos of two cars with big turbo both i beat off a roll nick will get to run them as well soon
Highland Kustoms /Instagram- Highland_srt SRT-4 ![]() |
#65 (permalink) |
![]() Join Date: Mar 2004
Member Number: 8941
We still need some logs to look at timing and KR.
I will say though, after seeing King's real boost levels, that S2000, well, somethings not being said.
20G Stage 3 on E85: New data:384 hp 411 tq
"Maybe I should just stick to bolt-ons." -Hitler I don't really want to wrench anymore. I'd rather detail. |
#66 (permalink) |
![]() Join Date: Aug 2005
Member Number: 32196
Honda was running like shit...
Kings car spools very slow for a stock turbo, And no tq steer at all? I'm sure its on tires no bigger than 225....Looks like a 250-260hp level. Data log shows it, need to boost leak test the car better.
17x8 245/40/17 ST40 BBK Project TRAIN DONE!11/13/09
04 -E-85 Ported Stock Turbo,Stock cams&Head,Stock Motor,Safc Neo 329.69Hp, 395.77Tq STD 297Hp@6K 320.87Hp, 385.18Tq SAE WTB Locked DSP,Built 5speed,SCT Prp |
#67 (permalink) |
![]() Join Date: Aug 2010
Member Number: 80561
s2k's are the most overrated car to race.
you can have a 700hp stock block s2k, but the tq is lower than hell, and peak power isn't made until redline, so a way less hp car can match or beat it.
Pumpking.
10.71@140. 1st SRT in TENS in CA. Thanks to: TUNED BY MINDMELT101@DRAG-ON Tuning. - http://drag-ontuning.com/blog/ GOKEY RACING for anything fabrication related instagram for updates and pics: m_santiago37 |
#69 (permalink) |
SRT of the Month ![]() Join Date: Aug 2005
Member Number: 32888
you can have a 700hp stock block s2k, but the tq is lower than hell, and peak power isn't made until redline, so a way less hp car can match or beat it. Really? He's was a local.
#70 (permalink) |
![]() Join Date: Jul 2008
Member Number: 65861
OK. Datalog has been made, and results are more typical than we thought. As I sat in the driver seat, I saw the boost gauge, it stays above 20psi for most of the powerband, than settles near 20psi by 6K. Unfortunately, it's not accurate.
3853 rpm's boost was 18.27 lbs of boost climbing @ 5057 rpm's it held 17.4 psi all the way to 5300 rpm's. by 5768 rpm's the boost had dropped to 15.11 psi and falling. Lol I don't see 370whp from his car like he claims on higher boost. That's ludicrous. This.. i just dont understand 10psi on a built motor,and he thought you were big turbo? he would of got destroyed by a big turbo
That S2K should've ran from him. I would guess that he would trap around 112-114. Sounds like a nice setup! That's not confirmed yet
![]() His Meth stopped spraying, but he fixed it. The car is strong, don't get it in your head that it's not. He's definitely made considerable progress with it. I think it's a typical stock turbo almost maxed out car.. Like i said stock turbo holding above 17 to redline doesent happen ROFL
I was gonna say your boost gauge is off, but what do i know, im chief and dont know jack shit. My question was gonna be log with map sensor data, it never lies unless clamped or altered with a piggyI hold over 17 flat at redline lol or I have before.. 17.03 at 60XX RPM's.
298whp/405wtrq on a dynodynamics 92 degrees out
stock turbo, bolt on's, E85, DSP, M&H's on Welds 60': 1.83 330': 5.030 1/8: 7.721 @ 93.17mph 1/4: 12.012 @ 114.22 R.I.P. 40 roll |
#71 (permalink) |
![]() Join Date: Dec 2010
Member Number: 82261
now thats a real S2K, i like how the SRT has a 60-trim with just bolt-ons. Sounds like alot of lag.lol
PTE 5858 .63AR ![]() 1000CC STOCK BOTTOM, CAMMED FULL SUPPORTING MODS 401@370 tuned by NIGEL contact Nigel(turbo666) for all your SRT needs |
#72 (permalink) |
![]() Join Date: Oct 2009
Member Number: 75930
you can have a 700hp stock block s2k, but the tq is lower than hell, and peak power isn't made until redline, so a way less hp car can match or beat it. |
#74 (permalink) |
i think the best he ever did was high 11s at 123 (the srt)
#75 (permalink) |
Member Number: 8941
Kings car spools almost instantly. The datalog shows it at 15psi before he even hits his max throttle voltage. Dont read the boost gauge.
LG-P999 using AutoGuide.C
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
