Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > SRT Videos
Old 06-30-2008, 05:26 PM   #16 (permalink)
nightmare_rebuilt's Avatar
Member Number: 42066
Trader Rating: (39)
Quote: Originally Posted by gump1114 View Post
no i read what you were saying correctly. and i understand what an adjustable FPR does... i have a returnline set-up myself
what i'm saying is that i seriously do not think that when you go WOT using a static FP that for each 1 psi of boost your fuel pressure will drop 1 psi.
OMFUKIN GOD!
FloridaSRTOwnersClub.
FS: BUILT SRT4 motor! 3k takes it, needs to go, buying a 68 mustang FL locals only pm me for specs on the motor!
nightmare_rebuilt is offline   Reply With Quote
Old 06-30-2008, 08:21 PM   #17 (permalink)
Member Number: 45523
Quote: Originally Posted by 98turboteg View Post
You will see a big difference with an after market wga. By the lack of tire spin I'm guessing your running about 18lbs of boost now...? After installing the PTP S3 wga and raising boost to 24lbs my clutch starting slipping pretty bad also. I have an ACT 6 puck on the way.
Looks smooth! Enjoy it.
yep im holdin about 18-19 psi now, im hopeing with a new wga i can hold 22+. Also my tires are fairly fresh still and the road i was on is only a couple years old and has MINIMAL traffic so i hooked up fairly well. Thaks for the input so far
One other question..... do most guys run the after market wga on the pcm or run off pcm boost?
S3R
Old 06-30-2008, 08:33 PM   #18 (permalink)
Member Number: 40273
Trader Rating: (21)
I dont know your setup, but even with 225/45/18 Kumho MX's my second gear is twice as bad as your first. You'll see once you crank up the boost and get a tune on it. Traction becomes an issue. Get ready to buy a clutch.
I've never used an AGP wga on this turbo, only the PTP. I couldnt get it to work on pcm control. Even with no preload it would spike to 25+. But I'm using a stage 2 pcm. I had to take it off of pcm control, but it works out better for me since I'm doing all the tuning anyway. It spikes to 24/23 and holds 22/21. Well it did, now I have it down to 17 until the clutch goes in.
S3Rh
Missing 04 Eblue as of 7/11/08.
98turboteg is offline   Reply With Quote
Old 06-30-2008, 08:35 PM   #19 (permalink)
Trader Rating: (21)
I've heard several people say the DAB still works with the AGP wga on PCM control.
Old 06-30-2008, 08:38 PM   #20 (permalink)
Member Number: 17118
Nice man, thanks for sharing. I think I am set on doing a S3 on my car this fall. I have been debating between that and the S3D kits but I think the Mopar kit is a better fit for me. You have plans on hitting the track anytime with it (when you get a new clutch of course!)?
- 04 SRT-4 | FP 47lb Green in the works
Louisvilleguy is offline   Reply With Quote
Old 06-30-2008, 10:16 PM   #21 (permalink)
o yea i plan on hitting up the strip for sure, I REALLY want 12's bad and i hope i can make it. From what i have seen street tires are a maybe but slicks i will be there for sure
Old 06-30-2008, 10:20 PM   #22 (permalink)
Trader Rating: (39)
it depends how much preload you give the wga, but yea it works.
Old 06-30-2008, 10:26 PM   #23 (permalink)
Member Number: 51111
decent vid but my god could your BOV be more annoying?
lVlemphizStylez is offline   Reply With Quote
Old 06-30-2008, 11:05 PM   #24 (permalink)
haha i don't even notice it anymore, sometimes when i think back ill be like was my bov working? i don't remember hearing it? haha I also use it to scare deer, they hear it and scatter
Old 07-02-2008, 11:52 AM   #25 (permalink)
Ghost_SRT's Avatar
Member Number: 36179
Yeah grab yourself the AGP WG. Mines setup like stock hitting 19-20psi on dab 0&1, and 25-26psi on dab 2&3. So you pretty much lose the functionality of the dab feature. But oh well, its worth it.
Stage 3 FNF | Maxxfab Stg3 o2 | CTI Charge Pipe | AGP Stg3 WG | N2MB Toybox | Thermal 3" Turboback| JMB UPP | HKS SSQ BOV | JMB SRI | Mopar Wires | NGK 4306 Plugs | Maddog 72% STS / Rod Brake | BC Coilovers | QW BFMIC | B-Woody MM's | AEM WB | 30/30 Boost Gauge | Aeroforce Pro Scangauge | Pizza Ball|
Fro G's garage. When you want to be fast in the PNW
Ghost_SRT is offline   Reply With Quote
Page generated in 0.23872 seconds with 11 queries
