c5 zo6 vs SRT-4 PTE 5858 - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > SRT Videos
Old 01-23-2013, 08:07 AM   #16 (permalink)
BlackBerry's Avatar
Member Number: 50792
Quote: Originally Posted by jay05acr View Post
Thanks for confirming the turbo that I want
I am pretty happy with mine. 5858 is plenty for the street.
BlackBerry is offline   Reply With Quote
Old 01-30-2013, 08:39 PM   #17 (permalink)
JMURDOCK20's Avatar
Member Number: 82261
hell yea another 5858 kill.its a street terrior i cant wait to turn the boost up to like 38 psi and let shiz get real.
PTE 5858 .63AR
1000CC
STOCK BOTTOM, CAMMED
FULL SUPPORTING MODS
401@370 tuned by NIGEL
contact Nigel(turbo666) for all your SRT needs
JMURDOCK20 is offline   Reply With Quote
Old 01-31-2013, 06:06 AM   #18 (permalink)
BlackBerry's Avatar
38psi on the stock bottom? I think this is where Kanye West comes in and says "That Shit Cray!?"
Old 01-31-2013, 01:41 PM   #19 (permalink)
JMURDOCK20's Avatar
noo, i need a couple more parts and my space block will be off to the machince shop.Then im going to go big.lol
PTE 5858 .63AR
1000CC
Old 01-31-2013, 02:57 PM   #20 (permalink)
BlackBerry's Avatar
Can't wait to turn my 5858 up. 20psi is fun. Amazing how some porting, headwork, and a built bottom end can make a turbo that size spool.
Old 01-31-2013, 04:18 PM   #21 (permalink)
JMURDOCK20's Avatar
my 27psi is crazy, adding another 12 is going to be nuts!!
PTE 5858 .63AR
1000CC
Old 01-31-2013, 05:20 PM   #22 (permalink)
ares559's Avatar
Member Number: 81082
Default c5 zo6 vs SRT-4 PTE 5858
Might have been discussed before but what trap speeds do you run at the track?
Sent from
SRT: AGP .50 trim
Tuning on E85.
Tuned by Mindmelt101
ares559 is offline   Reply With Quote
Old 02-01-2013, 02:21 PM   #23 (permalink)
Member Number: 80149
My only trip to the track was untuned (same boost level as now, just less timing and richer then). I went 98.X. I believe with the extra timing and having the a:f dialed in I should have picked up another mph or 3.
Murdock, make sure you swap the hotside out if you cross that 30 psi mark. Ported head or not, log manifold or tubular, you will lose boost with RPM on the .63 setup. Enjoy that 5858, it's an awesome turbo!
PTE 5858sp @ 24psi - Supporting Fuel - Stock internals
Contact Duster360 and Turbo666 for Diablosport tuning.
Quote: Originally Posted by thunt View Post
Ooooooh I get what your saying, because you don't drive it everyday means a:f's in the 16s are safe. My mistake...
jershelb is offline   Reply With Quote
Old 02-01-2013, 04:35 PM   #24 (permalink)
turbo srt4's Avatar
Member Number: 47173
^ speedo vid
turbo lag was invented so v8s could keep up
DELTA 46 417 WHP 429 WTQ
turbo srt4 is offline   Reply With Quote
Old 02-01-2013, 05:51 PM   #25 (permalink)
JMURDOCK20's Avatar
Hmm i didnt think about this yet. what all would it intel on changing? just the housing
PTE 5858 .63AR
1000CC
Old 02-01-2013, 09:46 PM   #26 (permalink)
khaoSrt4's Avatar
Member Number: 62825
Nice I was gonna get this turbo but was told to much for stock internals but now I see your doing just fine now I'm hmmmmm maybe. Are you also stock head studs and head gasket & what are your hp #s on this psi
khaoSrt4 is offline   Reply With Quote
Old 02-03-2013, 02:46 PM   #27 (permalink)
JMURDOCK20's Avatar
im stock bottom,head,studs,gasket and made the numbers in my sig at 25 psi. i think when i get some head work done and a built bottom end ill get a better tq number and then see spool a little faster
PTE 5858 .63AR
1000CC
Old 02-03-2013, 09:47 PM   #28 (permalink)
Quote: Originally Posted by turbo srt4 View Post
^ speedo vid
You kids and your speedo vids... :P
I have that run on youtube somewhere, my channel is jershelb.
Just the housing! no problem.
It's all stock. I was street tuned by Duster, no dyno numbers. Speaking in terms of usable power band on a stock longblock, i consider it to be a great turbo for the job. Knock on wood, i have had this guy up around 28-29 psi on race fuel and 25psi daily on pump with great results. 90k miles on the clock.
Old 02-03-2013, 10:32 PM   #29 (permalink)
KillaB's Avatar
Member Number: 85871
Same turbo I'm buying in a week.(stock long block e85) Just having a hard time deciding journal or ball bearing still. Lol I'll probably never get a bigger turbo then this so idk.
Sent from
2003 Solar Yellow
12.79 @108.23
KillaB is offline   Reply With Quote
Old 02-04-2013, 03:26 AM   #30 (permalink)
turbo srt4's Avatar
no kids here bud just want to see how laggy it is
