Quote: Originally Posted by
boost junkie
First let me say that you'll get a LOT more help on the 1st gen neon forums (there is a megasquirt section with a LOT of people that run megasquirt).
www.neons.org • Index page I really suggest posting there if you still have problems.
Thanks for the info, I'll sign up and post again.
boost junkie
#1 The LC1 has 2 outputs. One should be set for 0-5v linear and connected to the megasquirt. Then you configure the megasquirt to have a wideband input.
If you want to connect to the AFR gauge then you need to use the 2nd output on the LC1. This one you'd set for 0-1v linear (or whatever the gauge wants).
The thing about the outputs is that the gauge worked before we uninstalled the MS and the second output from the LC1 was taped off from PO. Could it be that it needs calibration since power was disconnected for over 3 weeks?
Also, the MS is like a computer right, so even disconnecting the power it should keep the memory and how it was tuned?
boost junkie
#2 your idle fluctuation problem could a LOT of different things. I'm going to need more information (and I suggest you post that information on neons.org). What MS firmware version? Are you running spark control? What is the engine setup? Injectors? Fuel pressure? Can you post your MSQ file and a datalog of it running?
I just called my friend who owns the car and knows almost everything done to the car, here is a pretty complete list of what there is:
Engine:
’99 Dodge Neon 2.0L DOHC
’04 SRT 4 Exhaust Manifold
’97 Intake Manifold
’97 Throttle Body bored to 72mm
56 ft/lbs Injector's
150 Amp Alternator
2.5” Straight Pipe w/ Dynomax Muffler
Cast Iron Block (good for 27psi)
Eagle 1 Forged Connecting Rod Bearings
Eagle 1 Forged Connecting Rods
Eagle 1 Forged Main Cap Bearings
Eagle 1 Forged Pistons
High Flow Aluminum Radiator (About 18” x 20” x 2.5”)
High Performance Oil Pump
High Performance Water Pump
Mopar Performance Camshafts
Mopar Performance Lifter’s
Poly-Urethane Engine Mounts
Stock Cast Iron Crank
Turbo:
’03 TD03 or TD04 Turbo
2 ¼ foot Dump Tube (2.5”)
2” Intercooler Piping
SRT 4 Blow-Off Valve
SRT 4 Front Mount Intercooler
SRT 4 Waste-gate
Transmission:
3.76 LSD Differential
Poly-Urethane Shifter Bushings
Poly-Urethane Transmission Mounts
SRT 4 Drive Axles
SRT 4 Flywheel
SRT 4 Transmission
Stage 3 Racing Clutch
Suspension/Brakes:
Front Neon Caliper’s in the back
Front Neon Disc’s in the back (Drilled/Slottled)
KYB GR-2 Shocks all around
Monroe Brake Pads
Poly-Urethane Control Arm Bushings
SRT 4 Front Brake Caliper’s
SRT 4 Front Brake Disc’s (Drilled/Slotted)
SRT 4 Mopar Lowering Springs
Fuel/Electric:
Aftermarket Fuel Filter
Aftermarket Pressure Regulator
Mopar Performance Fuel Pump (Up to 60psi)
10” Electric Radiator Fan
MegaSquirt Firmware V1
LC-1 Innovate Motorsport Lambda Sensor
