Old 10-02-2007, 11:07 PM   #1 (permalink)
Member Number: 25011
Default Post your timing map? please?
I am currently working on my timing map, looking to decrease EGTs in the cruise range and increase gas mileage somewhat, and from what I have read, my timing for cruise seems to be way too conservative for best efficiency, heres my map, I'm looking to compare it to other people's and/or to get some advice on making it more efficient
obviously I have work to do on this map, for one, I'm bringing the redline down to 7000rpm, I need to raise the timing out of boost, and maybe a small amount in boost too
wicked93gs is offline   Reply With Quote
Old 10-03-2007, 07:14 AM   #2 (permalink)
Member Number: 319
You're at about 15-25 degrees timing in the cruise range. That should be 30+ degrees.
Old 10-03-2007, 11:57 AM   #3 (permalink)
Technical Tuning & EFI/EMS Electronics moderator
sour kraut's Avatar
Member Number: 19796
Here's the "stock" map for an 04, or at least most of it. You can see what it runs during part throttle.
sour kraut is offline   Reply With Quote
Old 10-03-2007, 04:14 PM   #4 (permalink)
thanks, I redid my timing map to follow the stock SRT map, at least out of boost, I'm more conservative in boost though still
Old 10-03-2007, 09:22 PM   #5 (permalink)
well, the SRT map made a HUGE difference as far as smoothness goes, its now a lot more driveable than it was, though it still doesnt seem to have any more power oddly enough(it had plenty to begin with though so thats neither here nor there)
my new map, cant tell if its safe in boost yet(larger turbo so I pulled 5 degrees from everything in boost) but out of boost its fine
Old 10-04-2007, 06:46 AM   #6 (permalink)
Member Number: 12302
can you actually post that vex so i dont have to put all those numbers in
thanks.
SpecJ is offline   Reply With Quote
Old 10-04-2007, 08:14 AM   #7 (permalink)
I would, but I dont know how you can attach a file in a forum posting, generally only pictures are allowed
p.s. stop being a lazy bastard!
Old 10-04-2007, 09:57 AM   #8 (permalink)
sour kraut's Avatar
that's just the part throttle timing map. There's a completely different map for full throttle. I'm glad it helped though.
Old 10-04-2007, 01:55 PM   #9 (permalink)
I'll pull more timing from the boost side then, at low boost(5psi or less) though so far it works great
Old 10-04-2007, 09:06 PM   #10 (permalink)
haha... being lazy is where its at son! lol
God i wish my laptop wasnt 15 feet away from me and powered down....
Old 10-06-2007, 01:43 AM   #11 (permalink)
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
Good deal I will have to adjust my driving spark with what is posted here. I got my egt's going from 1700 at 70mph cruising down to just under 1500.....
Anyone know what the egt's are suppose to be while cruising? Like whats a safe range?
Old 10-06-2007, 01:57 AM   #12 (permalink)
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
from experience on my 50 trim I used more boost, but toned down the timing. I ran in the lower to mid 20's timing wise when I had the 50 trim under boost. Now that I have a bigger turbo it will be different so I have to start over. Also I dunno, but I dont think going above 40 degrees of timing is a good idea for part throttle? Between 1700 and 2300 rpm it will reference those cells with timing over 40. I guess if thats what the car runs on stock pcm it should be ok, but man thats alot of timing....makes me worry ya know. Not sure how much boost you plan to run, but will have to change the kpa values over on the left to reflect more boost. Thats where it starts making it a pain....well for me at least to adjust since now your cell range has been shrunk and is used more.
Well I will change my stuff tomorrow. Thanks peeps!
Old 10-06-2007, 02:14 AM   #13 (permalink)
this was mainly an out of boost map for me, but I have to say that part throttle driveability(up to 5psi) is excellent, and I have 9:1 compression and use a 20g turbo, I have my whole map so low in boost right now though because I have a few things I need to do before turning up the boost, mainly some I/C piping work(since mine is custom) and getting a boost controller of some type, probably a MBC to start with, then a solenoid I can wire into MS
Old 10-06-2007, 09:56 AM   #14 (permalink)
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
k kewl thats what I am going to use it for....the stuff from 5psi and below for drive ability and mpg. From then on everything will be totally different. Have an idea of what a good driving egt is?
Old 10-06-2007, 03:37 PM   #15 (permalink)
with this map, at cruise my EGTs are between 1000 and 1150, under slight boost it goes to about 1250...much better than my previous 12-1300 cruise and 1400+ in boost
Page generated in 0.22133 seconds with 14 queries
