Old 08-17-2007, 05:26 PM   #1 (permalink)
CASPERAMC's Avatar
Member Number: 40048
Default outputs
ok is there a way to have one of the outputs from the ms turn something on when above a certain rpm and at wot
or better yet on at before a certain rpm then turn back on after another i.e. below 3200 and above 4500
Old 08-17-2007, 08:21 PM   #2 (permalink)
Member Number: 319
You can turn on/off with several different variables. However, the code as it is won't do a "window". You could easily program it to do that though...
Old 08-17-2007, 09:05 PM   #3 (permalink)
CASPERAMC's Avatar
how would i go about doing that? the reason i am asking is because i will be getting an r/t intake manifold which has secondary runners that are open at low rpms, high rpms and WOT and id like the ms to run that
Old 08-18-2007, 11:51 AM   #4 (permalink)
Member Number: 319
It's all there in the manual.
http://www.msextra.com/manuals/MS_Ex...al.htm#outputs
Old 09-13-2007, 01:41 PM   #5 (permalink)
CASPERAMC's Avatar
ok to bring back my old topic, i will be doing this soon, and the way i see it, i need to use 2 different outputs to run this for the certain rpm values and also at WOT. unless i am missing something where i can set it to work with both, but is there a way to wire both output wires going to one place and not really mess things up as in a 12v going up tthe other wire and overloading the ms somehow(diode maybe? what kind?) and also to stop both of the wires giving a 12V to the target and doing something bad at that end
thanks
-mike
Old 09-14-2007, 09:51 AM   #6 (permalink)
guhfluh's Avatar
Member Number: 1745
Nitrous control output should work fine for what you are trying to do AFAIK.
guhfluh is offline   Reply With Quote
Old 09-14-2007, 01:43 PM   #7 (permalink)
CASPERAMC's Avatar
i dont think the nitrous control will work because it goes on after xxrpm AND at WOT
i need before xxrpm OR after xxrpm OR WOT
Old 09-14-2007, 04:04 PM   #8 (permalink)
guhfluh's Avatar
Member Number: 1745
It switches an output on after xxxx RPM and back off before xxxx RPM when TPS above yyy. Use the normally closed portion of the relay so when the MS activates the "nitrous" control after xxxx RPM it will open your circuit.
Old 09-14-2007, 04:38 PM   #9 (permalink)
CASPERAMC's Avatar
yea but does the tps still have to be above something because i need it to be on when im just cruisig at low rpms too
Page generated in 0.15772 seconds with 11 queries
