Old 08-02-2007, 06:55 AM   #1 (permalink)
Member Number: 319
Default MS1/Extra trigger settings
What is the final word on the trigger settings? This is what I have:
Wheel Decoder
Wheel decoder base teeth: 36
Missing teeth: -2
Trig pos A: 11
Trig return pos A: 16
Trig pos B: 29
Trig return pos B: 34
Spark Settings
Trigger Angle: 62
Old 08-02-2007, 02:14 PM   #2 (permalink)
Member Number: 12302
Wheel Decoder
Missing teeth: -2
Trig pos A: 11
Trig pos B: 29
Spark Settings
Trigger Angle: 62
Thats what I am using, of course I am getting some hiccups at 2250, 3100, etc.. and my damn laptop broke. I'm going to try and make some adjustments, but timing seems to be ok everywhere else. My problem might be fuel related.
SpecJ is offline   Reply With Quote
Old 08-02-2007, 07:34 PM   #3 (permalink)
CASPERAMC's Avatar
Member Number: 40048
yea im runnin that, slight hiccup at around 3500ish, but i think its also fuel related.
Old 09-22-2007, 08:27 AM   #4 (permalink)
Member Number: 38100
Hi , We testing a new MS1 on a SRT swap. I have loaded the NGC3 in the MS and first we trying to start the car...spark was set to Neon/a420 thinking the code ngc3 have been put in neon mode. Car never start We got fuel and spark..but not at the right time.
So..we have to set the spark to Thooted Wheel and enter the wheel setting like the one on this treath. Any other hink to know? There not much NGC guide so not easy to find info.
It will be cool if there a NGC option in Spark setting whit all the wheel setting filled up.. Only a suggestion
Thank
I already run a MS1-extra setup in my 2.2 16v conversion Dodge omni and run like a charm! I'm using a 36-1 on the crank and a set of neon coil pack. Spark & fuel is rock solid, start everytime and run strong (118mph trap speed @ 18psi).
turbogui is offline   Reply With Quote
Old 09-22-2007, 07:48 PM   #5 (permalink)
Member Number: 319
There's no NGC option because all you have to do is configure as a 36-2 wheel.
Old 09-22-2007, 08:41 PM   #6 (permalink)
vschaos's Avatar
Member Number: 3626
Trader Rating: (15)
I will go look at what my settings are at....I have no hiccups at all....brb.
Edit: Mine is exactly as above.
Old 09-23-2007, 09:10 AM   #7 (permalink)
Car have fired and run whitout a problem..Need to be tuned only
Old 07-24-2008, 03:08 PM   #8 (permalink)
R/Tony's Avatar
Member Number: 22637
Hey Gui whatsup
I need to get tunned also, you have to help me !
Holset user
R/Tony is offline   Reply With Quote
Page generated in 0.16065 seconds with 13 queries
