How would I determine what size trigger wheel I should use for the MSnS-E? I know you guys are working on a way to avoid it, but I wanted to get setup with it (MS) soon using a trigger wheel and then switch over later.
Now someone said I would need a 60-2 wheel, the guy said I shouldn't use the 36 tooth wheel, what determines that?
And what diameter should I get? I have seen all kinds of sizes of 60-2 wheels.
Take the wheel/sensor from an old neon. They have that up and running complete now.
Okay you lost me. You mean the old neon's run a trigger wheel and vr sensor?
Or did you mean the srt4's can use the same trigger wheel setup that the old neon's run for standalone's? If so, what setup is that and where do I get it?
I have seen trigger wheels one Ebay but they just list sizes, I haven't been able to find anywhere that says "this size for this car/setup" (I haven't even seen any trigger wheels on the MS parts sites)
The SRT wheel works now. You'll have to figure out the trigger points with a generic wheel. Might as well do it with the wheel thats built into the crank.
Bare with me, I am not an idiot just real new to the MS thing. I can't be the only one that is lost (at least I hope not )
Okay, so I figured that using a trigger wheel could bypass what you guys are trying to figure out (the spark part of the MS for the SRT). I thought it would be possible to mount a trigger wheel and vr sensor and use that to determine the spark/timing. Is that not right?
You can but you still have to figure out the trigger teeth, etc. Basically the same thing you have to do with the stock wheel. Might as well just use the stock one.
I can guarantee that as of this writing they have them in stock
Look under "Connectors" -> "Multec 3.5 Fuel Injector Connector"
Steve
Ah ha! Now I know I didn't have any reason to click on that link the way it was presented... I must have got there some other way. Thanks for the help.
Steve
Darren
No problem. It'll probably be changed to read something like "Multec 3.5 Fuel Injector Connector (Neon, Ford SVT, etc)"
Steve
Darren
Steve
Haha. Us challenged people need blatant labels staring at us in the face. I just ordered a few things tonight, but there was a script saying that none of the things I ordered were in stock in the quantities that I requested. ???
“Believe in yourself. Believe in your own potential for greatness. Believe that you can change the world. It is something that is within each of us.”
Steve
Darren
Steve
That's wrong. I'll PM you. Must have to fix something.
So has anybody had any luck testing this yet? Beyond what I've already done by getting the car to run with the MS controlling the coil pack.
I would go further but I've lost my test car and I haven't spoken to the owner yet about getting it back. I probably won't until mid June after I get back from a trip to Texas. Driving the 3600 mile round trip MS powered btw
