Old 07-24-2006, 09:10 AM   #1 (permalink)
SRToc Member
Member Number: 2005
Trader Rating: (20)
Default Megasquirt build question
Guys,
I am in the process of building my MS1 v3.0. I am at the point where I decide which sensor input I want to use (VR or HALL).
So umm, which one do I want since I am "hoping" to be able to tap into and use the NGC (No separate crank trigger).
Or should I just install both styles onto the board? The instructions mention installing both and just jumping once I decide. Anything wrong with that way (i.e. possible shorts or problems down the road??)
Greg 04-SRT4
Greg_04-SRT4 is offline   Reply With Quote
Old 07-24-2006, 09:56 AM   #2 (permalink)
2000neon2SRT-4's Avatar
Member Number: 36347
Trader Rating: (46)
I would got with whatever the instructions says, MS intructions are pretty acurate i have no hands on experiance with the V3 i build a v2.2 and its running perfect on 00 stratus srt set up.
You can contact boostjunkie he helped me alot on setting up my MS.
2000neon2SRT-4 is offline   Reply With Quote
Old 07-24-2006, 11:29 AM   #3 (permalink)
Member Number: 17652
I have built 4 3.0's and all of them I build the whole MS complete and go back and do the mods. Build the hall and the VR, test it ensure it works correctly, then do the mods. This way if something is wrong u know it has to do with the mods instead of guessing if its the mods or the MS.
2001dodgeneonrt is offline   Reply With Quote
Old 07-24-2006, 11:52 AM   #4 (permalink)
SRToc Member
Member Number: 2005
Trader Rating: (20)
Thanks guys.
Old 07-25-2006, 12:41 PM   #5 (permalink)
gennro's Avatar
Member Number: 22121
I just built the Hall effect on my board since thats what the NGC crank uses. I personallly myself would just build the hall setup and test it with your stimulator
04 srt-4
Mods:
Blown engine
Leaking 50 trim turbo
Fat driver
Dirt
gennro is offline   Reply With Quote
Old 07-27-2006, 07:05 AM   #6 (permalink)
Member Number: 31017
Trader Rating: (80)
now we just need to get the ngc code to work without the hiccup at 6200
if not to the drawing board i go
richie
2acrguy is offline   Reply With Quote
Old 07-27-2006, 11:09 AM   #7 (permalink)
Member Number: 319
It's still not verified that its a code issue. From the debug logs I've seen its decoding properly at 6200.
Old 07-28-2006, 04:04 AM   #8 (permalink)
2acrguy, can u get the ms working and load that code? We need someone to put a timing light on it to verify the code is correct.
Old 07-28-2006, 12:11 PM   #9 (permalink)
SRToc Member
Member Number: 2005
Trader Rating: (20)
I will probably just do that. but the instructions mention something about firing using the neg terminal of the coil. Is that what we need or can I skip that step??
Old 07-29-2006, 09:21 AM   #10 (permalink)
Member Number: 319
Skip that. Just build the hall circuit as shown on the schematic. Test the board with the stim. Once you verify everything works, do the neon mods...
Page generated in 0.24446 seconds with 11 queries
