Old 04-25-2007, 06:42 AM   #1 (permalink)
Member Number: 319
Default Megasquirt-2 reads NGC crank signal!
Here we go again. We just now got ms1/extra working on the NGC and the MS2/extra developers have added support for the NGC wheel. This is very early alpha test code. Realize that it will probably have bugs.
General info: http://www.msextra.com/viewtopic.php?t=23867
Thread for testers: http://www.msextra.com/viewtopic.php?t=24247
Advantages over MS1? 16-bit chip with much higher precision for both fuel and spark calcuations.
Cost? Extra $90. Simply unplug the ms1 cpu from your board and plug in the MS2. External wiring should be the same.
Old 04-25-2007, 03:26 PM   #2 (permalink)
Overcome's Avatar
Member Number: 24451
This'll have to wait a while, but I'm always up for it.
“Believe in yourself. Believe in your own potential for greatness. Believe that you can change the world. It is something that is within each of us.”
– Evan Michael Tanner 1971-2008
Old 04-25-2007, 07:09 PM   #3 (permalink)
CASPERAMC's Avatar
Member Number: 40048
booooo they couldnt do this a couple months earlier
Old 04-25-2007, 10:04 PM   #4 (permalink)
Member Number: 319
What difference does it make? All the wiring and everything is the same. Just plug in a different cpu onto your board.
You didn't waste money. The MS1 chip is only $12.
Old 04-26-2007, 12:31 PM   #5 (permalink)
CASPERAMC's Avatar
o haha i thought i would have to rewire everything. ill stay with ms1 for now anyway just to get it started
Old 06-23-2007, 12:25 PM   #6 (permalink)
Member Number: 319
Anyone try this out? It's a shame the MS2 developers wrote the decoder for NGC and nobody is jumping on it..
Old 06-23-2007, 05:36 PM   #7 (permalink)
Member Number: 54881
I'd be willing to try it out...
here's a related question, on the SRT4 engine, what trigger angle is the NGC wheel mounted at? I.e., what should my trigger angle be, and if you have suggest trigger teeth - that'd be helpful!
I must be missing something, but I didn't see any MSQs floating around here.
thanks,
-scott
EDIT - nevermind, found what you guys were using for trigger settings!
we're about to try and fire up our SRT4 test car here in a few minutes!
-scott
dieselgeek is offline   Reply With Quote
Page generated in 0.17195 seconds with 13 queries
