Old 03-13-2008, 09:57 PM   #1 (permalink)
Member Number: 61275
Default Mega Log Viewer TQ Numbers
224lb/ft @ 3050
260lb/ft @ 3900
284lb/ft @ 4800
Numbers stopped there cause I blew a boost line off when I hit 5000 RPM.
This was at 15.5 PSI on SRTturbofold. Data entered into Mega Log Viewer:
Vehicle Weight: 2600 (2493 stock + 160 for me, and 35 lbs for gas , -88lb weight redux wich is actually very conservative)
gear ratio: 1.36 (3rd gear)
final drive: 3.94 (1999 r/t trans)
Tire Diameter: 23.5 (215/40/17)
no wheel spin during pull since I rolled onto WOT at 3k rpm instead of punching it.
My Question: Do these numbers seem like abnormally high to anyone else for only 15.5 psi on my listed sig mods?
1999 R/T with: JE Pistons, Eagle Rods, 8.88:1 Compression, Heavily P&P Head, Oversized valves, DOHC Crane 14s, SRTTurbofold, 577 cc Injectors, MSnSExtra, Fidanza Flywheel, MPX UDP, Mattdog SS, Booger Bushings, Custom DA Koni Coilovers, Fidanza Cam Gears. Custom Kevlar Clutch, PLX M-300 WB o2, AEM SRT4 CAI, Treadstone Big FMIC, P&P Intake Manifold, UDP, AC delete, 3" O2 Housing, 3" Catless DP.
Now (back) on 16 PSI 2.0L
Max Sleeper is offline   Reply With Quote
Page generated in 0.13300 seconds with 13 queries
