Old 03-06-2008, 04:23 AM   #1 (permalink)
Member Number: 50568
Default Few MS questions
To make the MS read my AEM wideband I just connect AEM WIDEBAND Blue(serial output) to the 02 signal of the MS and adjust and set up the MS wideband signal at 2.35 volts?
How can I install the shift light. I just need to run this cable to the positive of the shift light? them adjust it on megatune
the launch control, boost controller and table switching can be activated by a control switch?
i have a turbo xs dual boost controller, it have a control switch to change boost level via a boost solenoid, I will like to make that when I switch to higher boost my MS table switch, can i make this ?
thanks, 4 all
sweetshibi is offline   Reply With Quote
Old 03-06-2008, 10:30 PM   #2 (permalink)
Member Number: 39105
No, not the serial output of the wideband. The 0-5v output.
The rest of your post is a little ambiguous. I'm pretty sure you're right about the shift light. Someone else chime in. I don't know what else you were saying.
esteinmaier is offline   Reply With Quote
Old 03-07-2008, 04:47 AM   #3 (permalink)
Well I'm saying that with an external manual switch if I can active the table switch operation and also the launch control
Right know I'm running my srt with a dual boost controller, that have a manual switch in the cabin to change between boost level, i just want to hook up the table switch operation to the boost controller manual switch, so daily i can use a mild table with lower boost and when I flip the switch I can have higher boost and a race map
I have the super420a v.3.0 from rs
but the instructions for the extra functions only says jumper X__ (for extra input/output)
Old 03-07-2008, 08:24 AM   #4 (permalink)
smokin-ricers's Avatar
Member Number: 10183
Trader Rating: (10)
if I recall correctly it is the blue wire and they do call it serial output when in all reality it is just a blue wire.
I am not sure if the super 420A has this built in to it but this is what you will need to do click me or click me
from what i understand yes they can here is the link for the table switching you want click me
thanks, 4 all
you should be able to do this but you may have to use 2 separate toggle switches 1 for the boost controller and 1 for the fuel table or you could wire 2 relay's up to activate at the same time with one switch
really you could wire as many relays as you needed to activate at the same time i hope this makes sense
I am STOCK
Ya know what I mean
DevilsOwnOnline
smokin-ricers is offline   Reply With Quote
Old 03-07-2008, 03:27 PM   #5 (permalink)
hey thanks a lot
that was the info I was looking for
Old 03-07-2008, 07:46 PM   #6 (permalink)
Trader Rating: (10)
hey thanks a lot
No problem I am currently in the process of wiring up my M/S and also in the process of writing up a how-to with hopes of getting it made into a sticky but with a newborn little girl spare time to work on the srt-4 is almost non-existent I am trying to compile all the info into one easy to understand and easy to find location and also to put a safe base-tune in the same thread to get everyone started and running fairly easy there is alot of good info in this section but also some not so good info.
Old 03-08-2008, 07:31 AM   #7 (permalink)
RED: 12v power
BLACK: chassis ground
WHITE: 0-5v output
BLUE: serial output
DO NOT connect the blue wire to the megasquirt. It's the white one. The megasquirt is reading a sensor as a sensor. The blue wire is used for AEM's own EMS.
Page generated in 0.16722 seconds with 11 queries
