Old 02-27-2007, 01:45 PM   #1 (permalink)
CASPERAMC's Avatar
Member Number: 40048
Default constants questions
what is the injector open time of a stage 1 injector, -solved
what is the battery voltage correction, -solved
what is the fast idle threshhold,
how many squirts per engine cycle 1? -solved
my req fuel is 5.8. is that right because i read that itis supposed to be between8 and 12-solved
and
is there a suggested injector staging setting or is simultaneous good-solved
i was reading about the barometric correction option and it seems good should i just turn it on?
thanks maybe ill get this going some day lol
-mike
Old 02-27-2007, 10:56 PM   #2 (permalink)
Overcome's Avatar
Member Number: 24451
I believe it should come out to 8.6 or so. And you want injector staging to be alternating and squits per engine cycle should be 2 as the number of squirts must divide evenly into the number of cylinders.
“Believe in yourself. Believe in your own potential for greatness. Believe that you can change the world. It is something that is within each of us.”
– Evan Michael Tanner 1971-2008
Old 02-27-2007, 11:15 PM   #3 (permalink)
CASPERAMC's Avatar
im running a 2.0L with srt stage 1 injectors, would that account for my low req fuel?
Old 02-28-2007, 01:58 AM   #4 (permalink)
Overcome's Avatar
Oops. Wasn't aware that this was a 2.0L. It'll be more around 7.3 then.
Old 02-28-2007, 07:01 AM   #5 (permalink)
Member Number: 319
Don't worry about what the REQ_FUEL actually comes out to. Just use whatever works.
Old 02-28-2007, 05:30 PM   #6 (permalink)
CASPERAMC's Avatar
ok cool what about the rest of the stuff though? thanks
Old 03-01-2007, 12:13 AM   #7 (permalink)
Member Number: 319
http://www.msextra.com/manuals/MS_Ex...ing_Manual.htm
Old 03-01-2007, 03:40 AM   #8 (permalink)
Overcome's Avatar
So when do we lame SRT owners get to see phase sequential/semi sequential code? What kind of issues are you still running into?
Old 03-01-2007, 01:55 PM   #9 (permalink)
CASPERAMC's Avatar
ok looks like my constants are set up good. thanks alot
Old 03-03-2007, 02:15 AM   #10 (permalink)
Member Number: 319
I guess someone needs a working setup first. 8)
Old 03-03-2007, 04:28 AM   #11 (permalink)
Overcome's Avatar
Fine I'll get to working on it again.
Page generated in 0.16007 seconds with 13 queries
